Author Topic: flywheel removal/ broken magnets  (Read 2157 times)
December 08, 2011, 09:40:38 PM
Re: flywheel removal/ broken magnets
« Reply #15 on: December 08, 2011, 09:40:38 PM »
Aaron, the good thing is, the little one isn't yours!!  Enjoy your young life, my friend! :cheers:  :cheers:
December 08, 2011, 09:44:36 PM
« Reply #16 on: December 08, 2011, 09:44:36 PM »
That had to be awkward.
December 08, 2011, 09:50:00 PM
« Reply #17 on: December 08, 2011, 09:50:00 PM »
Quote from: "Circle Hooked"
To say the least...
December 08, 2011, 09:50:37 PM
« Reply #18 on: December 08, 2011, 09:50:37 PM »
indeed it was :shock:
December 09, 2011, 05:59:56 PM
« Reply #19 on: December 09, 2011, 05:59:56 PM »
got the flywheel off this morning,
let it sit over night under tension, tightened it some more this morning, tapped with the hammer, popped right off, picking up the new flywheel tomorrow night...
as i suspected, the stator didnt sustain and damage...
December 09, 2011, 06:35:12 PM
« Reply #20 on: December 09, 2011, 06:35:12 PM »
Quote from: "Aswaff400"
 :cheers:  :cheers:  :cheers:  :salut:
December 09, 2011, 09:24:51 PM
« Reply #21 on: December 09, 2011, 09:24:51 PM »
:cheers:  :cheers:  :cheers:  :cheers:
An Ex came over with her newborn?  yeah awkward isn't quite enough!  LOL
December 10, 2011, 09:11:55 AM
« Reply #22 on: December 10, 2011, 09:11:55 AM »
Aaron,
One thing you may be tempted to do but do not do is to put grease on the crankshaft or flywheel taper surfaces in order to keep from this happening again. DO NOT DO IT! I learned this a long time ago working with tapered tooling in the machine shop. It causes an hydraulic effect between the surfaces and when you torque it down the tapered surfaces will not mate together correctly and eventually will loosen and possibly damage the crankshaft, keyway, flywheel or you could have the flywheel come off while running. When I was an apprentice toolmaker I made the mistake of lubricating a tapered seat lathe chuck to keep it from sticking when changing chucks. The 20# chuck came off at about 1500 rpm just missing my head and destroying a $900 chuck when it it the floor. I was lucky I didn't get killed. But worse was the remaining 3 years of my apprenticeship listening to the heckling from the journeymen everytime I approached one of the lathes to turn up a piece of steel. Just clean the surfaces up and torque it down.
December 10, 2011, 09:21:12 AM
« Reply #23 on: December 10, 2011, 09:21:12 AM »
Arron, Ex-girlfriend?  Kids?  This video should provide a little clarity....
https://www.youtube.com/watch?v=dIHxkSe1l3c
December 10, 2011, 09:36:50 AM
« Reply #24 on: December 10, 2011, 09:36:50 AM »
Quote from: "Blue Agave"
http://www.youtube.com/watch?v=mtTUOfIN ... ata_player
December 13, 2011, 11:44:52 AM
« Reply #25 on: December 13, 2011, 11:44:52 AM »
picked up a replacement flywheel this morning for 50 bucks from a guy in palm harbor... the guy used to own a 19-6 FF and a 22-2... :cheers:
December 13, 2011, 12:12:43 PM
« Reply #26 on: December 13, 2011, 12:12:43 PM »
Well you can't beat that price!
December 13, 2011, 09:02:40 PM
« Reply #27 on: December 13, 2011, 09:02:40 PM »
got the flywheel on today, motor runs good...
noticed the timing wasnt advancing when pushing the throttle... had to squirt some pb in that adjustment thing, still gets hung up. spring feels weak/tired...
