Author Topic: Remove sludge in bilge  (Read 862 times)
December 01, 2011, 10:51:05 PM
Read 862 times
rucamana
« on: December 01, 2011, 10:51:05 PM »
Hello everyone, Im trying to clean up a  lot of sludge in the bilge of my 225 Explorer. My guess is that the PO spilled some oil before I bought it and was never cleaned.
I use a product called Heller Glanz bilge cleaner which help a lot but it ran out pretty quick and I still need more, the only bad thing is that cost $20 a gallon + almost another $20 for shipping.
Is there any other chemical out there that can help?
Thank you,
Ruben,
2000 Aquasport 225 Exp Tournament Master
December 01, 2011, 10:58:47 PM
Re: Remove sludge in bilge
« Reply #1 on: December 01, 2011, 10:58:47 PM »
Try this.  Put the garboard drain plug in, shoot a decent amount of Dawn in the bilge, fill about 1/3 of the way full from the hose, then walk away and have a beer.  Let the Dawn do it's thing.
1/2 hour later, pull the drain plug, and continue to hose down the bilge.  Keep it up after most of the water drains out, you'll still have a lot of suds in there.  Keep hosing it down until the suds have gone away.
You'll be surprised what Dawn can do.  One of the reasons most boat builders have cases of it on hand... :thumright:
December 01, 2011, 11:10:06 PM
rucamana
« Reply #2 on: December 01, 2011, 11:10:06 PM »
Thank you for the prompt reply,
I thought about Dawn bc when the oil spill in the Gulf they showed on TV using it to clean some animals and specially the birds.
I have not been out for at least 3 months, will take it out for a warm up this weekend and will use the Dawn before leaving the dock on my way back home, by time I arrive it should be better, then a good wash
thanks again
Ruben,
December 01, 2011, 11:12:26 PM
« Reply #3 on: December 01, 2011, 11:12:26 PM »
Welcome ruca, what year is your Explorer?
I second the Dawn it's good stuff and cheap  :salut:
It's also a great dog shampoo, kills fleas on contact.
December 02, 2011, 09:16:33 AM
« Reply #4 on: December 02, 2011, 09:16:33 AM »
Put the Dawn (or other cheapo dishwashing soap) in the bilge with some water - then take the boat out and run it around a bit.  Jump some wakes, make some tight turns, etc.  What you want to do is get that stuff sloshing around in the bilge.  The sloshing is what breaks up the grime and sludge.  Then pull the boat out and drain the bilge.  Usually comes out clean and even smells nice!   :thumleft:
December 04, 2011, 10:03:14 PM
rucamana
« Reply #5 on: December 04, 2011, 10:03:14 PM »
The Aqua is a 2000, with a Johnson 200, I have been out boating for a few years but this my first own and I love it. I dont think 200hp is enought for it when you have over 4 people but it gets me where I need to go..
I was hoping to do the Dawn wash-up this weekend but plans changed and was not possible, maybe next weekend, will keep you folks posted.
Ruben,
December 04, 2011, 11:02:10 PM
« Reply #6 on: December 04, 2011, 11:02:10 PM »
I have a 200 on my 97 and i agree, more the 4 people is pushing it both power wise an room wise but I have done it many times, trim tabs are a must to get it up and going with alot of people, when the day comes to re power I will put a 250 on her.
December 05, 2011, 12:31:21 PM
« Reply #7 on: December 05, 2011, 12:31:21 PM »
Quote from: "Circle Hooked"
You may want to play around with propping a bit.  My 200 Merc 2-stroke pushes my 22-2CCP pretty well - 43-44 MPH at 5300RPM top end and good hole shot.  I am running a 5-blade Quicksilver 19 pitch that really made a difference compared to the 3-blade I was running before.
December 05, 2011, 09:28:34 PM
rucamana
« Reply #8 on: December 05, 2011, 09:28:34 PM »
I wonder how one of the new eTec 300 will move the Aqua.... :shock:
Ruben,
December 05, 2011, 10:35:32 PM
« Reply #9 on: December 05, 2011, 10:35:32 PM »
Quote from: "rucamana"
She was rated for 300, offered back then in the form of twin 150s.  She'd be better with twin 200s.
With twin 150s, we saw mid 50s on her sister, the 225 Osprey.  The Explorer obviously weighs more, but a single cuts down on drag.  I'd guess 47 with a single 300 Etec...
December 06, 2011, 09:53:33 AM
Capt Matt
« Reply #10 on: December 06, 2011, 09:53:33 AM »
For sale 300 etech with 2 yrs of warranty left,
drop me a PM if interested
Capt Marr
Light tackle sportfishing
December 06, 2011, 02:56:57 PM
rucamana
« Reply #11 on: December 06, 2011, 02:56:57 PM »
I'm concern about the weight with twin 150's, plus I need to add more rigging, dual control, cables, change my new instrument panel, etc...its more security for the boater out there with twins for sure but I dont go out to far from shore, a single 300 will do the job and if it stops working BoatUs will do the rest...
Ruben,
