Props
68 22.2 flatback prop selection
Topic: 68 22.2 flatback prop selection (Read 2225 times)
February 25, 2006, 08:38:24 AM
Read 2225 times
68flatback
February 25, 2006, 08:38:24 AM »
i need to replace the prop on my 150 merc xr2..i have a 22.2 flatback with a 40 gallon fuel tank..the boat is pretty much stock no tower or t top.what would be my best choice for size of prop?any ideas?
February 27, 2006, 07:27:29 AM
Mako254
Guest
February 27, 2006, 07:27:29 AM »
Just some stuff on the mako site.
http://www.classicmako.com/forum/topic. ... IC_ID=8104
February 27, 2006, 11:19:16 AM
Mako254
Guest
check your pm's
February 27, 2006, 11:19:16 AM »
The 34th Annual Tournament will be held on Saturday June 17, 2006 at the Guy Lombardo Marina Freeport, LI.
April 13, 2006, 12:48:52 PM
Ben87
April 13, 2006, 12:48:52 PM »
On the 87 150 Merc I've had, I've been using a 15 X 17 inch prop forever and have had spot-on performance.
April 14, 2006, 06:26:14 PM
captflatback
April 14, 2006, 06:26:14 PM »
I just put a MERCURY MIRAGE 3 BLADE STAINLESS PROPELLOR on my flatback and i love that prop i think it is the 16th or 17th prop i've tried. It is a bow lift prop i have good top end and comes out of the hole great.
Capt. Jim Lemke
April 14, 2006, 06:38:09 PM
April 14, 2006, 06:38:09 PM »
What's different about the Mirage prop?
April 17, 2006, 09:36:29 AM
captflatback
April 17, 2006, 09:36:29 AM »
The ears on the prop are a lot bigger then a normal prop. The mirage is made to give max bow lift for heavy boats at low speed. The mirage is a great prop. The local Merc dealer will let you try one, mine did.
Capt. Jim Lemke
813-917-4989
www.lighttackleadventures.com
September 01, 2006, 11:58:42 AM
bluedolphin
Guest
'68 Flatback question
September 01, 2006, 11:58:42 AM »
Hey, '68flatback. We started a thread under the "Classified" section about a '66 flatback here in Miami, Fl. Can you post some pictures of yours, if you get a chance? The one in Miami has the side swim platform, and viewing ports in the hull - you can see pictures of the boat and these features in the thread. Thanks. I'm seriously thinking of buying this boat, but would like to see what she will look like after fixing her up.
Props
