Aquasport Discussion
Any idea on a livewell on a 22.2 EF
Topic: Any idea on a livewell on a 22.2 EF (Read 1088 times)
November 20, 2011, 05:52:39 PM
Read 1088 times
elbori00
November 20, 2011, 05:52:39 PM »
Im thinking on adding a livewell on my boat. Thinking of using it as a seat as well. Any ideas or anyone has done it or where I can get one.
Thanks in advance,
Alberto
November 20, 2011, 08:29:44 PM
elbori00
Re: Any idea on a livewell on a 22.2 EF
November 20, 2011, 08:29:44 PM »
Sorry forgot to add is a 1983 EF!
November 21, 2011, 05:24:12 AM
November 21, 2011, 05:24:12 AM »
I'm not sure where you'd put it, maybe if you get a small round plastic one you can put it in the corner at the aft? Maybe put a swim ladder/platform on the back and mount it there?
November 21, 2011, 09:38:43 AM
Mechanical Master
November 21, 2011, 09:38:43 AM »
Do you have the spashwell? I installed mine on the spashwell gate, and it is removable for times when I don't need it. I used starboard for the supports, the water is pumped from a pump connected to the factory thru-hull under the deck:
November 21, 2011, 03:26:06 PM
wessnapp
November 21, 2011, 03:26:06 PM »
Check this out:
http://www.classicaquasport.com/phpbb3/viewtopic.php?f=6&t=7861
Group W Bench is a great guy who does awesome work.
St. Petersburg, Florida
November 22, 2011, 10:13:59 PM
Group W Bench
November 22, 2011, 10:13:59 PM »
Alberto,
Que lo que hay.
November 23, 2011, 06:51:41 AM
elbori00
November 23, 2011, 06:51:41 AM »
Todo bien y usted! Usted es el que hace los livewells?
November 23, 2011, 10:15:44 AM
Group W Bench
November 23, 2011, 10:15:44 AM »
Si, tengo los livewells. Puedo enviarlo a Carolina. Hace muchos anos, estaba en Hato Rey cada mes en el Banco de Fomento.
November 23, 2011, 12:57:14 PM
elbori00
November 23, 2011, 12:57:14 PM »
Esos son los unicos que haces o puedes hacerlo "custom"?
November 23, 2011, 01:03:16 PM
Group W Bench
Reply #9 on:
November 23, 2011, 01:03:16 PM »
Como no, podemos hacer qualquier estilo que quieres. La differencia es el precio entre los los dos. Hay algo en particular que quieres?
November 23, 2011, 03:31:47 PM
elbori00
Reply #10 on:
November 23, 2011, 03:31:47 PM »
Le voy a enviar una foto del bote y mas o menos lo que me gustaria hacer. Este fin de semana se lo envio. Para que tenga una idea seria el livewell con 2 espacios al lado para usarlo como asiento.
Gracias,
November 23, 2011, 03:49:56 PM
Group W Bench
Reply #11 on:
November 23, 2011, 03:49:56 PM »
El correo electronico es
eugene@shipokeboats.com
. Por favor incluye dimensiones approximadas del tamano.
November 23, 2011, 04:26:27 PM
Reply #12 on:
November 23, 2011, 04:26:27 PM »
Que este es "tamano"?
November 23, 2011, 04:35:31 PM
Reply #13 on:
November 23, 2011, 04:35:31 PM »
Something ain't right here - did I press 2
November 23, 2011, 05:09:01 PM
elbori00
Reply #14 on:
November 23, 2011, 05:09:01 PM »
Quote from: "slvrlng"
Size
Sorry not everytime I can speak on my first language over the internet.
CC2 turn off.
