Author Topic: how to drain carbs 2001 honda 4 stroke 90 hp  (Read 714 times)
November 15, 2011, 09:09:27 PM
Read 714 times
maxwell18
« on: November 15, 2011, 09:09:27 PM »
as above, anybody got info on draining carbs on 2001 honda 90 hp 4 stroke for storage?
November 15, 2011, 10:17:49 PM
Re: how to drain carbs 2001 honda 4 stroke 90 hp
« Reply #1 on: November 15, 2011, 10:17:49 PM »
Quote from: "maxwell18"
Isn't your motor fuel injected?
November 16, 2011, 08:14:09 AM
maxwell18
« Reply #2 on: November 16, 2011, 08:14:09 AM »
I wish it was.....got four carbs
November 16, 2011, 09:06:17 AM
« Reply #3 on: November 16, 2011, 09:06:17 AM »
Most if not all outboard carbs have a brass or stainless plug at the bottom of the float bowls that can be unscrewed for draining. The question is getting access to them. Usually the top two are not a problem, but the third and especially the fourth can be a challenge.
November 17, 2011, 09:26:31 PM
Group W Bench
« Reply #4 on: November 17, 2011, 09:26:31 PM »
Maxwell,
You should only have 3 carbs. At least my Honda 90's have 3 carbs. Basically, you start at carb 3 and pull the drain hose and place the end in a bottle. Unscrew the carb 3 drain but don't take it all the way out. When 3 is empty, drain carb 2 through the carb 3 drain leaving drain 2 loose. Then do carb 1 the same way, draining through the drain in carb 3.
