On mine, I access the hose and thru hull fitting by removing the stern louvers. I can reach down and fiddle with it. Not sure if that applies to jdupree or not. Mine is located port side. If your's is like Mr Osprey then disregard this.I can't figure out how to replace my fuel overflow vent.
If you use a die grinder, the "rib" that conceals the hoses can be "trimmed" back under the gunwale which hides it from view but gives you some degree of access. Check measurements to make sure, but this was done on mine.
