Author Topic: Aquasport 210Xf Information Anyone?  (Read 2063 times)
November 04, 2011, 08:18:31 AM
Re: Aquasport 210Xf Information Anyone?
« Reply #15 on: November 04, 2011, 08:18:31 AM »
I'm curious as to where this hull was built. If you can, would you be so kind as to see if it is readable on the Coast Guard capacity sticker. Past indications would be at the Wellcraft plant in Bradenton/Sarasota but I wonder. :scratch: A little farther north may be in order. Just thinking out loud.
As to the engine, I can't speak. I'm sure the pistonheads will be along soon. I do know a close friend had one on his Seacraft and it ran really well but that can be said, at one time or another for all brands.
Thanks and we'll be waiting for the pics. :thumleft:
November 04, 2011, 10:53:47 AM
« Reply #16 on: November 04, 2011, 10:53:47 AM »
I'm sure Fitz would know for sure, but I think the motor is a 2.5 liter model, and Black Max motors were generally 2.4.  Mercury really does not go by year model - they go by serial number, so the same serial number could be a 1989 or a 1990 depending on when it was sold.  However, the motor does look clean.  Run a compression check and see if you get consistent values from one cylinder to another -  all 6 should be within 10 PSI or so of each other.  The motor should start up well and idle smoothly - rough idle or missing is a sign of problems that can cost some $$$.  Check for shifting from forward and reverse and check for leaks or cracks in the lower unit/gearbox.  These Mercs are pretty trouble-free when they run - problems are usually pretty obvious.
November 04, 2011, 11:06:45 AM
« Reply #17 on: November 04, 2011, 11:06:45 AM »
I think the 2.5L came out in 1991
November 05, 2011, 08:46:37 AM
210xf
« Reply #18 on: November 05, 2011, 08:46:37 AM »
Found another 210XF for sale in Mattituck, NY with a blown Merc. Boat shows listed as a 1987 Aquasport Walkaround. check it out: http://www.boattrader.com/listing/1987- ... d-99957912
November 06, 2011, 06:48:25 PM
210xf
« Reply #19 on: November 06, 2011, 06:48:25 PM »
Here is the HIN#
I cranked up the motor today and Pressure Checked it as well and all 6 came in at 120-125. Only concern was that it took about 2-3 min for the motor to start peeing at the top and when it did the water was coming out steaming hot, approx. 160 degrees as we collected the water coming out into a cup and put a thermometer in there. The seller said that it may be the impeller that needs replacing. What do you guys think?
November 06, 2011, 07:05:38 PM
« Reply #20 on: November 06, 2011, 07:05:38 PM »
210,
I'm not a Mariner guy but you'll get you answers. Johnson/Evinrude/Yamaha could very well be the impeller because water should flow through these motors just after start up (couple of seconds). Changing the impeller/thermostats/pressure relief valve would be SOP on this or any motor new to you so probably not a deal breaker.
By now I'm sure you realize we are not real familiar with this hull. I haven't seen it before but that really doesn't mean anything. I can't make out the first letters in the HIN. Do you know what they are?
Also, I looked at the "87" you linked to; looks like you type hull also so...
If you can find the capacity plate and see where the hull was built, that will be great information for the Forum. You may have stumbled on to the real transition WAC hull between the late 80's and early 90s.
As far as build quality, ride and performance, this is all new to me anyway. I'm learning just like you.
Good luck and you just may wind up with a rarer model than most. :thumleft:
November 06, 2011, 09:13:48 PM
« Reply #21 on: November 06, 2011, 09:13:48 PM »
If your running the motor on muffs and it hasn't been run in a while it may take a moment for the cooling system to fill up.  If you buy the boat I would recommend what Bob says and replace the impeller, t-states, fuel pump diaphragms and poppet valve.  This way you know what you are starting off with.  Also a set of plugs, fuel filter and service the lower unit too.
November 08, 2011, 06:22:09 AM
« Reply #22 on: November 08, 2011, 06:22:09 AM »
Good advice on the engine to do list. Go through it to establish a maintenance base line. The 2.5 was a very good engine and at on time was "the" engine to hop up and race. Very durable and with a lttle care would last many years. Your compression numbers seem right where they need to be. As with all older engines; check the entire fuel system for hardened or brittle fuel lines and replace. Replace the water separating fuel filter in the boat and inline fuel filter in the engine. The lack of water out of the discharge except a trickle was kind of normal on these because the discharge hose(s) were attached to the thermostat housing base and didn't start to flow until the thermostats began to to open which is what you experianced. The engine has two thermostats, one on each cylinder head the should be replaced when you do the waterpump.
November 08, 2011, 12:28:43 PM
« Reply #23 on: November 08, 2011, 12:28:43 PM »
Quote from: "fitz73222"
Thanks Fitz & CJ.  :salut:
I told ya the pistonheads would know the answer. Looks like the power plant is good.
Anything more on the hull itself?
November 08, 2011, 04:33:04 PM
« Reply #24 on: November 08, 2011, 04:33:04 PM »
I just looked at the boat spec sheet provided by Capt'n Bob. That hull weighed 3100#? What a tank! I would be curious of what propeller pitch and WOT rpm she is hitting. I cant imagine her turning more than a 17 pitch and turning more than 5300 rpm. Thats alot of boat for a single 200 if the weight is right?
November 08, 2011, 09:55:55 PM
« Reply #25 on: November 08, 2011, 09:55:55 PM »
I h ave a 17" prop on my 200 XF and I can turn 5600 RPM or more...   I doubt that thing would weigh much more than my XF does.    Also my 200 doesn't pee very much until the t-states open up...  and when it does it's hot water
November 10, 2011, 10:15:54 AM
210xf
« Reply #26 on: November 10, 2011, 10:15:54 AM »
Thanks guys for all of your information and guidance! I am supposed to be picking up the boat this Saturday and I will then start to go through the motor. As for being a heavy hull, it sure lokks loke it as its very beamy. I will keep you guys posted with any other pics once I get her. Thanks again!
