Author Topic: Prop selection for 175 with Evinrude 115 SPL  (Read 1110 times)
November 01, 2011, 02:03:50 PM
Read 1110 times
kchaudha
  • NorthEast
« on: November 01, 2011, 02:03:50 PM »
Just wondering what props folks are using.  Was going to grab a spare for my 175.  It's a 1998 and I have a 115 SPL on it from the same year.
Anyone have good/bad experiences with different sizes/pitches of props on a similar rig?
KC
Concord, MA
1998 175 w/ 115 Evinrude
November 02, 2011, 09:07:04 PM
akbridge
Re: Prop selection for 175 with Evinrude 115 SPL
« Reply #1 on: November 02, 2011, 09:07:04 PM »
I don't have a 115 on my 170.  But I do have a sweet running 90 evinrude.  And I have played a lot with props.  You should stick with a 17" pitch.  I would use a factory style OMC SST 13 7/8"x17" prop.  They perform good and and are priced right.  Do you have any needs you want to change that a prop may be able to cure?  Holeshot, porpoise, over-reving, ventilation/cavitation?
November 03, 2011, 12:14:26 PM
« Reply #2 on: November 03, 2011, 12:14:26 PM »
Here's a start, if you haven't read it already. If not, first one's free.
viewtopic.php?f=8&t=6417
The Resource forum is your friend.
PS... Once you have your desired prop, post to the thread with your results. :thumleft:
May 25, 2012, 07:57:56 PM
floridamisser52
« Reply #3 on: May 25, 2012, 07:57:56 PM »
I' agree with akbridge. I've got the same boat,and  same year as yourself , but the motor  is a 1998 evenrude 90 spl. My pitch is a 17' inch as well. I use the boat for tubing and fishing mainly and the prop pitch is right on even though the boat is  overloaded by 50 lbs or so at times. Good luck!
