Author Topic: The Inside the gunnel rod holders  (Read 1354 times)
October 20, 2011, 07:43:27 AM
Read 1354 times
HIFLUTIN
« on: October 20, 2011, 07:43:27 AM »
The Inside the gunnel rod holders-( Man I love those ) on my 17 has holders for 2 poles.
Seems like there is enough room for a 3 rod holder.
Has anyone fabed anything like this?
The length of the cover on the cavity seemd like it could be opened up.
any suggets?
October 20, 2011, 09:27:53 AM
flfisher
Re: The Inside the gunnel rod holders
« Reply #1 on: October 20, 2011, 09:27:53 AM »
are you referring to the rod holders that run the length of the gunwale?
if so you can make them out of boat board or teak with a jigsaw and a router
FLoridainshoreangler.com
October 20, 2011, 10:47:45 AM
daniel123
« Reply #2 on: October 20, 2011, 10:47:45 AM »
I'm about to mount a set of TACO horizontal rod holders (made out of Starboard) in my '71/72 170. I have a pair of two-rod and a pair of three-rod holders and both fit in the space, but the in-wall openings on my boat, which look like yours but have that white, textured plastic-coated-metal trim material on the edges (anyone have a cheap source for that trim material? I need about 7 feet of it to trim the anchor locker as well as the toe rail and radio access areas on the helm...) look like they may be a bit narrower than yours from top to bottom. When I temporarily placed the two sizes of racks in the compartments to test for location, I found that there really isn't enough room height-wise to comfortably fit three rods and reels in the three-rung holder though. The rack fit but the uppermost rungs for rods was not fully accessible -- at least at the end of the in-wall opening that was smaller height-wise than the other. I may stick with the two-rung rack on one side and see how that works. It also appears that the compartments are not 'deep' enough width-wise to keep the reel handles from jutting out where you can bang your legs on/break them as you walk by. My 170 doesn't appear to have ever had rod racks in either side, which seems like a waste of space -- but the dimensions of the in-wall compartments may be why.  Were in-wall rod racks an option on the 170?
October 20, 2011, 10:51:54 AM
« Reply #3 on: October 20, 2011, 10:51:54 AM »
Quote from: "daniel123"
Its actually called windlace I believe. Was popular with old cars for trim. Try googling it and see what you get
October 20, 2011, 02:41:54 PM
« Reply #4 on: October 20, 2011, 02:41:54 PM »
The biggest problem with space is posed by spinning reels.  Conventionals (bait casters, levelwinds, etc.) work pretty well.
