I'm sure the 'prep' work requires a lot more time than the actual painting, since the paint will bring out every flaw underneath. Sand, sand, sand. Sand. Not trying to spend your money here, but maybe someone can 'weigh in' on whether it makes sense to do all the prep yourself, buy the paint & assorted chemicals, and pay someone to shoot the paint.
Hey all. I have a 76 170. I want to do the hull sides in "Aquamist" awlgrip, and the liner in "Mattehorn White". I've been reading the website and the directions are pretty intimidating. I will be spraying the paint on...and I've never done this before. I plan to do a few coats of high build primer before I paint. I think I understand what I need to do before the final paint. My questions are as follows:1. Is a quart enough to paint the hull sides of a 17?2. Do I need to add a "Converter" for the paint to work in my spray gun?3. Is the two part poly the best for this application? What is EASIER, as I have no idea what the hell I'm doing.Any advice would be greatly appreciated!Kind Regards,-Christian
I'd check about having a vinyl wrap applied before I would ruin my boat with a terrible paint job. It takes a lot of experience to properly execute a paint job like this. It also takes a lot of money in tools to do it properly. If your looking at this as a way to teach yourself something and pay for your equipment for further use down the road then go for it. Otherwise, pay to have it done, do some prep to save money, etc. Your looking at a 10cfm+ compressor, oil sep, air dryer, spray gun, da sander, etc. $1000 dollars in tools easy if your buying decent equipment. Maybe half that if you buy used. Plus paint materials, time, spray location, etc.This paint works as a system, laymen rarely understand that. That finished job is only as good as each component to the entire job, from initial prep, to sanding and buffing it out. If your really wanting to learn how to do it you'll need to find a material to use and read the manufacturers application directions, prep, thinning, gun tip sizes, psi, etc. Its a long road that takes years of experience to become proficient in finishing. I wouldn't bother attempting it unless you can use it later on in life.
