Author Topic: Any one have a clue as to what type of transducer this is?  (Read 2476 times)
October 10, 2011, 04:34:49 PM
Read 2476 times
HIFLUTIN
« on: October 10, 2011, 04:34:49 PM »
Worth keeping?
October 11, 2011, 10:34:37 AM
Re: Any one have a clue as to what type of transducer this is?
« Reply #1 on: October 11, 2011, 10:34:37 AM »
Quote from: "HIFLUTIN"
Worth keeping?
Funky!   :afro:
I would take it off and fill the hole ASAP.
October 11, 2011, 11:35:47 AM
« Reply #2 on: October 11, 2011, 11:35:47 AM »
Cannot say I've ever seen one like that before...but I can find out!
October 11, 2011, 12:59:00 PM
« Reply #3 on: October 11, 2011, 12:59:00 PM »
That is strange  :scratch:
October 11, 2011, 05:23:50 PM
Hawg Hunter
« Reply #4 on: October 11, 2011, 05:23:50 PM »
Is that a spacer above it :scratch:  to angle it in a down position?
Capt, Richard "DUKE" Bowen
Conyers Ga
1988 290 Aquasport XF
October 11, 2011, 09:25:57 PM
« Reply #5 on: October 11, 2011, 09:25:57 PM »
Hey, I'm tryin', but so far, no dice.  Semperfishing, he know's his chit, he's an electronics vendor out in CA...
http://www.thehulltruth.com/marine-elec ... -like.html
October 11, 2011, 10:37:16 PM
« Reply #6 on: October 11, 2011, 10:37:16 PM »
That sucker is pulling some serious turbulence.
I'm with John....get that zit gone.
Not sure what it is. Was the boat formerly used commercially...like survey work, mineralogy, etc?
One way or the other...get rid of it, the top end/fuel economy will improve.
October 11, 2011, 10:45:09 PM
« Reply #7 on: October 11, 2011, 10:45:09 PM »
Agreed...
October 12, 2011, 08:41:19 AM
« Reply #8 on: October 12, 2011, 08:41:19 AM »
External thru-hull transducers extend beyond the hull’s surface and
usually require a fairing to aim the sound beam vertically. They are
right for larger un-trailered vessels. When external mounts are
installed with a High-Performance Fairing, the transducer face is
flush with the surface of the fairing and parallel to the waterline,
resulting in a truly vertical beam, putting maximum energy on the
target. This installation, when mounted in “clean water,” forward
of propellers and running gear, produces the most effective signal
return, since nothing on the vessel interferes with the transducer’s
active face.
Pretty good huh. :mrgreen:
Here's what a quick search found
http://www.si-tex.com/ChoosingaTransducer.pdf
Yours doesn't appear too streamlined to me though. :o
October 17, 2011, 02:39:49 PM
« Reply #9 on: October 17, 2011, 02:39:49 PM »
HIFLUTIN,
Can you post a better pic of your "transducer"?
October 18, 2011, 07:27:59 AM
flfisher
« Reply #10 on: October 18, 2011, 07:27:59 AM »
I would check with airmar since they make most transducers.
FLoridainshoreangler.com
October 20, 2011, 07:31:56 AM
HIFLUTIN
« Reply #11 on: October 20, 2011, 07:31:56 AM »
Guys decided to take off
Run in skinny water & might get knocked around.
It a bad-_ss unit-all brass etc.
I wonder if it could used as a thru-hull?
October 20, 2011, 09:51:34 AM
c master
« Reply #12 on: October 20, 2011, 09:51:34 AM »
I had a similar size unit on my 40' sailboat.  Mine would read accurately to about 1000' depth...maybe more.  But I doubt it would have been a good choice for a planing hull, except at non-planing speeds.
The hole needs to be filled correctly.
C Master
1975 Aquasport 170
file:///C:/Users/cliff.haehl/AppData/Local/Temp/IMG_0135.jpg
October 20, 2011, 06:37:51 PM
« Reply #13 on: October 20, 2011, 06:37:51 PM »
I saw one like that on "Shipshape TV" and he was changing it out for a "shoot through the hull" type. Of course he is "good friends" with everyone and gets everything for a good price. (free)
October 20, 2011, 07:19:53 PM
« Reply #14 on: October 20, 2011, 07:19:53 PM »
Ah hell, it's just an old Airmar "football".  That first pic you posted didn't give any indication that it is what we're used to.
Yes, you can use it as a shoot-thru.  Just make sure there is no coring in the area you mount it...
