Author Topic: Trolling Motor Quick Connect Question  (Read 731 times)
October 04, 2011, 08:23:13 PM
Read 731 times
wessnapp
« on: October 04, 2011, 08:23:13 PM »
What type of quick connectors do you guys use/recommend for trolling motors?
St. Petersburg, Florida
October 04, 2011, 09:16:21 PM
Re: Trolling Motor Quick Connect Question
« Reply #1 on: October 04, 2011, 09:16:21 PM »
Do you mean for the motor mounting or for the electrical connections?  Also, what kind of motor are you planning to use?  Bigger motors need bigger mounts!
October 04, 2011, 09:31:43 PM
wessnapp
« Reply #2 on: October 04, 2011, 09:31:43 PM »
Good point - initial question was vague.
24Volt MinnKota Riptide needs a quick connector for power.
October 04, 2011, 10:11:32 PM
« Reply #3 on: October 04, 2011, 10:11:32 PM »
Marinco twist-lock.  Keep dielectric grease on the prongs and it will last.  Mine is going on 6 yr. old.  The pin type are worthless.
October 04, 2011, 11:09:19 PM
Capt Matt
« Reply #4 on: October 04, 2011, 11:09:19 PM »
For the power line a marinco twist lock, If you are looking for a quick release bracket a dog bone is the way to go
Capt Matt
Light tackle sportfishing
