Author Topic: rub rail off & there is 4 -1" diameter holes  (Read 928 times)
October 04, 2011, 05:48:41 PM
Read 928 times
HIFLUTIN
« on: October 04, 2011, 05:48:41 PM »
Took my rub rail off & there is 4 -1" diameter holes that go thru the Hull cap on each side
They were filled with 5200.
Does anyone know if this from the factory?
If so for what?
October 04, 2011, 06:58:12 PM
Re: rub rail off & there is 4 -1" diameter holes
« Reply #1 on: October 04, 2011, 06:58:12 PM »
Not sure without pics.
October 04, 2011, 07:52:49 PM
« Reply #2 on: October 04, 2011, 07:52:49 PM »
Quote from: "HIFLUTIN"
If so for what?
Emphatically, NO, that wasn't from the factory!  Are the holes in proximity to any vent hoses or pump discharges?  This I'd like to see...
But, as always...
October 10, 2011, 08:00:14 AM
gman 82 aquasport
« Reply #3 on: October 10, 2011, 08:00:14 AM »
I have a 82 Aquasport 19.6 with the same type holes in the cap and hull, was told by a local boat guru that they were for cap alignment when origonally installed... made sense but not totally sure it's accurate..
1982 19-6 Osprey
1992 Johnson 150
"THERAPY"
Member # 2331
October 10, 2011, 04:40:56 PM
HIFLUTIN
« Reply #4 on: October 10, 2011, 04:40:56 PM »
Here is a pic of whats on mine.
Not sure of what it is
May 26, 2023, 07:18:25 AM
Sea-senior
« Reply #5 on: May 26, 2023, 07:18:25 AM »
I have holes in a similar area , more like slits i guess i havnt removed the rub rail to verify but heres a pic of what i can see .
