Trailers
Bias ply or radial?
Topic: Bias ply or radial? (Read 1781 times)
October 02, 2011, 06:53:52 PM
Read 1781 times
Bias ply or radial?
October 02, 2011, 06:53:52 PM »
which one should i do? i trailer often, usually 2 to 3 times a week, mostly city, but will be towing highway regularly now too...
ordering new tires and rims, going with some shiny aluminum rims to match the shiny paint
1996 200 Osprey
SOLD
1968 22-2 Flatback
SOLD
1993 210 Explorer
SOLD
1991 Fountain 31TE
SOLD
1989 Fountain 12-meter
SOLD
1992 Talon F-20
SOLD
October 02, 2011, 07:42:18 PM
Re: Bias ply or radial?
October 02, 2011, 07:42:18 PM »
Cheapest ones - you won't be towing far enough regularly to need to spend the extra on radials (not sure the value of a radial on a trailer anyway).
October 02, 2011, 08:17:36 PM
October 02, 2011, 08:17:36 PM »
I have both on different trailers now,if you are going to tow often and on the interstate radials all the way,they ride better and run cooler and you should get alittle better gas mileage over Bias,Bias ply hold up from sitting better but they get alot hotter.
I have Radials on my work trailer and Bias on the boat trailer because it sits more.
October 02, 2011, 08:35:15 PM
October 02, 2011, 08:35:15 PM »
I agree with Scott. If I did tons of highway towing I would go radials. I just can't justify the expense. My tires dry rot way before they wear out.
October 02, 2011, 09:27:22 PM
October 02, 2011, 09:27:22 PM »
one thing to consider, payload
payload for 175/80R13
bias ply: 1,100 lbs each, 4,400 lbs total
radial: 1,360 lbs each, 5,440 lbs total
the trailer came with radials, and rated for 5440 lbs...
1996 200 Osprey
SOLD
1968 22-2 Flatback
SOLD
1993 210 Explorer
SOLD
1991 Fountain 31TE
SOLD
SOLD
1992 Talon F-20
SOLD
October 03, 2011, 07:09:04 AM
MarshMarlowe196
October 03, 2011, 07:09:04 AM »
I would go with Radials. The biggest reason would be less risk of blowout. Nothing like a blown trailer tire to ruin an otherwise good day on the water (or prevent you from making it to the water at all).
Radials have much less resistance to rolling than ply, so when you're in a situation where you're pushing your boat around on the trailer with man power, you wont throw your back out trying to do so.
I know you're going with a tandem axle so this might not be a big concern for you, but radials track much better so you have less chance of "sway" while you're towing, not to mention they don't wear nearly as quick as ply.
You could always get some of those cheap tire covers and keep em' covered while you're not using the boat. This would help prevent the dry rot, and your radial tires could last the life of your boat.
Key West 1720 / Yam C90
Sold: 1973 Aquasport 19-6
October 03, 2011, 08:14:00 AM
October 03, 2011, 08:14:00 AM »
i went ahead and ordered radials.
i keep the boat and trailer inside at my work, only sun exposure it gets is when its used
blow out does scare me... kinda... a customer of mine had a blowout towing his proline o n the interstate. ripped his aluminum fender right off and did a good amount of gel coat damage... we had a blow out on our 13 ft atv trailer few months back, ripped the fender right off...
ordered a set of these :)
1996 200 Osprey
SOLD
1968 22-2 Flatback
SOLD
1993 210 Explorer
SOLD
1991 Fountain 31TE
SOLD
SOLD
1992 Talon F-20
SOLD
October 03, 2011, 01:03:22 PM
October 03, 2011, 01:03:22 PM »
Great choice
October 03, 2011, 03:47:54 PM
Mechanical Master
October 03, 2011, 03:47:54 PM »
Nice! Radials are the way to go for Jesse's reasons above - less rolling resistance, less sway, and more capacity.
October 03, 2011, 04:04:10 PM
Rigging Master
Reply #9 on:
October 03, 2011, 04:04:10 PM »
The rims too? Awesome!
October 03, 2011, 04:14:44 PM
Reply #10 on:
October 03, 2011, 04:14:44 PM »
yes
lol, they should look good under this
1996 200 Osprey
SOLD
1968 22-2 Flatback
SOLD
1993 210 Explorer
SOLD
1991 Fountain 31TE
SOLD
SOLD
1992 Talon F-20
SOLD
October 04, 2011, 07:53:20 AM
Reply #11 on:
October 04, 2011, 07:53:20 AM »
got my tracking munber, should be here friday morning
1996 200 Osprey
SOLD
1968 22-2 Flatback
SOLD
1993 210 Explorer
SOLD
1991 Fountain 31TE
SOLD
SOLD
1992 Talon F-20
SOLD
October 07, 2011, 05:51:37 PM
Reply #12 on:
October 07, 2011, 05:51:37 PM »
got my tires in this morning via Fedex, picked them up on lunch and took an extended lunch break to install them...
new hubs and bearings
1996 200 Osprey
SOLD
1968 22-2 Flatback
SOLD
1993 210 Explorer
SOLD
1991 Fountain 31TE
SOLD
SOLD
1992 Talon F-20
SOLD
October 07, 2011, 06:21:26 PM
Reply #13 on:
October 07, 2011, 06:21:26 PM »
October 07, 2011, 07:48:28 PM
Rigging Master
Reply #14 on:
October 07, 2011, 07:48:28 PM »
Bud, those look awesome on that trailer! Trucks looking pretty good too!
Trailers
Bias ply or radial?
