Author Topic: Installing a Tach on small OB  (Read 821 times)
September 23, 2011, 09:43:04 PM
Read 821 times
« on: September 23, 2011, 09:43:04 PM »
I have a 25 hp Johnson pull start motor,no charging system,also have some old working Tach's in the shed,is it possible to hook a Tach to the Johnson and how would i do it,thanks guy's  :salut:
September 23, 2011, 10:27:42 PM
Re: Installing a Tach on small OB
« Reply #1 on: September 23, 2011, 10:27:42 PM »
Dammit, Scott, where's the gearheads when you need them?  I know it can be done, stator area, or something like that...
September 23, 2011, 10:33:48 PM
« Reply #2 on: September 23, 2011, 10:33:48 PM »
Scott,
Neat little vid here on a tiny tach...http://www.youtube.com/watch?v=HMr7UTcmatY
Just extend the leads to the helm or wherever...and I bet you can do this with any tach... :thumright:
September 23, 2011, 11:04:01 PM
« Reply #3 on: September 23, 2011, 11:04:01 PM »
I did know about tiny tach,maybe it can be done,a tach should be a tach i think  :scratch: so ground to ground and ign to #1 plug wire sound right.
September 23, 2011, 11:23:42 PM
« Reply #4 on: September 23, 2011, 11:23:42 PM »
So what happens if you try?  It doesn't work?  Oh, well.  Works?  Cool....
September 23, 2011, 11:43:21 PM
« Reply #5 on: September 23, 2011, 11:43:21 PM »
Tiny Tach has something for any motor.  They even have one for diesels.  A little sensor clamps to a fuel injector line and senses the fuel pulses.
September 25, 2011, 04:22:16 PM
« Reply #6 on: September 25, 2011, 04:22:16 PM »
You can run a regualar marine tach off the stator on a 25, just like any other motor.  You will need to set the tach for the correct pulse setting for that application.
September 26, 2011, 08:23:12 PM
« Reply #7 on: September 26, 2011, 08:23:12 PM »
Quote from: "GoneFission"
That sounds like what i wantd to hear,gonna try it and see what happens,will let you know how it goes.
September 26, 2011, 09:23:40 PM
« Reply #8 on: September 26, 2011, 09:23:40 PM »
On a Johnson I think the setting is for a 12 pole pulse.
September 27, 2011, 10:41:21 PM
« Reply #9 on: September 27, 2011, 10:41:21 PM »
Quote from: "slvrlng"
I think that would work on mine...    :oops:   Yeah!!!!    :albino:
