Author Topic: Transom- Should I fix it or not?  (Read 2988 times)
September 23, 2011, 08:55:39 AM
Read 2988 times
Curious
« on: September 23, 2011, 08:55:39 AM »
So a while back I posted that the top cap on the transom was cracked and asked you guys if I should repair the transom:
One of you said to just bolt the motor on and use the boat until it gets really bad.  Before I took the old motor off, I jumped up and down on the cavitation plate and the transom seemed really solid- very little flex.  But.......  Yesterday, I removed an old transducer from the lower starboard side of the transom and the screws had the telltale black mud on them and the holes pretty much leaked water.  Oh, and the boat hasn't been in the water for at least 6 or 7 years.  Now I'm thinking I have a transom rebuild on my hands.  If I do it, I would dig it out with the drill/chainsaw method and pour with Seacast or Arjay.  By the way it's a 1975 22FF. Based on yesterday's findings and the cracked top cap, what do you guys think?
Dan
1978 22 Family Fisherman
1996 Yamaha 200 SW Series
September 23, 2011, 09:26:17 AM
Re: Transom- Should I fix it or not?
« Reply #1 on: September 23, 2011, 09:26:17 AM »
That looks pretty bad to me.  I'd say fix it now before more damage is done.
September 23, 2011, 09:50:25 AM
« Reply #2 on: September 23, 2011, 09:50:25 AM »
Always remember that your motor pushes forward on the transom. The crack is developing because of this force. The mulch at the bottom only confirms what you already know. A transom with a crack like that could let go at any moment. My concern about pouring yours would be the crack itself. You really need to repair that area from the inside with several layers of 1708. If you just chainsaw it out I don't think you will have enough room to do a proper job. JMHO.
September 23, 2011, 10:58:18 AM
« Reply #3 on: September 23, 2011, 10:58:18 AM »
Curious...Since she's a '75...any inclination to do the deck/stringers also?
September 23, 2011, 11:31:20 AM
c master
« Reply #4 on: September 23, 2011, 11:31:20 AM »
From the look of that crack, you really have to fix it properly.  So it's either a lot of 'sweat-equity' type work on your part, or your hard-earned money to pay a professional.  But there is an "added value" to rebuilding the transom:  You can go ahead and take it to full height, which (IMHO) looks very nice and functions well.  Take a look at the Photo Gallery 22's.
My guess would be that if the transom is in bad shape, the stringers/deck are equally as water-logged - at least at the aft end.
It's a slippery slope...you'll end up wanting to paint the hull after you re-build.
But hey!  You've got a ton of knowledge/support here at the site.
C Master
1975 Aquasport 170
file:///C:/Users/cliff.haehl/AppData/Local/Temp/IMG_0135.jpg
September 23, 2011, 07:43:14 PM
Curious
« Reply #5 on: September 23, 2011, 07:43:14 PM »
Thanks for the input, guys.  I'm not too knowledgeable about this stuff but I'm fairly handy and I have a couple of brothers who are really good with fiberglass and wood so I plan on putting them to work.  Gran, I have no inclination to get into a full rebuild like the ones I've seen on here, although I have a feeling that you're asking me because you know the stringers are most likely saturated.  What I would like to do is grind the top cap off, dig out the wet mulch in the transom, pour Seacast or Arjay, recap and be done with it.  My question is, if the stringers are saturated, am I wasting my time?  All I'm really looking to do is get a few years out of it.
C Master-  I would love to fully enclose the transom and mount a bracket.  But I'm on a limited budget and I have a 20" 200 Yamaha Salt Water Series motor ready to go on the boat. I don't mind the sweat equity but the real equity is limited!
Dan
September 24, 2011, 07:21:02 AM
« Reply #6 on: September 24, 2011, 07:21:02 AM »
Well, you're right. But the good news is that the stringers are void of wood....well almost void (there is a small strip of plywood running inside that acted as a support until the foam set) so yep, other than wet foam on the inside, the stringers glass-wise should be okay. This is probably the biggest reason these boats are still around/being rebuilt today; there is actually something to rebuild to.
Heck yea, crank up the Stihl and have at it :lol:
If you get out all of the mung (particularly at the base) you should be fine. A long piece of solid steel will help with the digging, and a leaf blower, shop vac, etc. Get her dried out good before you start the pour.
There are threads here to help. Keep us posted :thumright:
September 24, 2011, 08:36:31 AM
Curious
« Reply #7 on: September 24, 2011, 08:36:31 AM »
Thanks Gran.  I watched some Youtube videos and one guy used a round rasp on the end of a drill extension that helped clean up the glass before the pour.  I also plan on drilling out as much as I can with a long spade bit before firing up the chain saw.
Next question-  What is the general consensus, Arjay or Seacast?  Cost comparison?  And where would I get it, I live in the Northeast.
Thanks again!  Hopefully I'll have some time soon to tackle this.
Dan
September 24, 2011, 08:45:35 AM
« Reply #8 on: September 24, 2011, 08:45:35 AM »
You got it, and good luck.
Captain Bob may move this thread to Rebuilds so the boys can come on and input regarding the fill material question.
Have a great weekend :thumright:
September 24, 2011, 10:47:38 PM
« Reply #9 on: September 24, 2011, 10:47:38 PM »
Had a great discussion with fitz regarding this. The transom and stringers on our 22-2's are independent. That is, the transom is a closed fiberglass unit. The stringers are closed (albeit wet) units. Per design, there should be no transfer of water from the stringers to the transom base.
The board consensus is that stringer leakage occurs from above, due to screw/hole leaks in the floor (console bedding) over the years. And the reason the decks go soft on either side of the console.
The stringers at the stern base tab/join directly to the interior transom fiberglass skin. No direct transfer of water from one to the other occurs. The interior fiberglass transom skin extending to the hull bottom blocks it.
At least in theory... :mrgreen:
September 26, 2011, 10:33:03 AM
c master
« Reply #10 on: September 26, 2011, 10:33:03 AM »
Fitz, Seabob, etc.:
That transom crack in "Curious"'s first photo is in sort of a strange place, no?  It looks like the outboard "face" is pushed out, and perhaps the inside face too.  I'm wondering what would cause that?   Wood swelling?
If it's getting re-built anyway, it doesn't matter, but I wish I could see more photos of it.
C Master
1975 Aquasport 170
September 26, 2011, 11:15:48 PM
« Reply #11 on: September 26, 2011, 11:15:48 PM »
Quote from: "Curious"
Curious, thanks.
Arjay vs. Seacast as pour material...Hopefully Matt can chime in here. Thanks.
September 27, 2011, 09:35:02 AM
Capt Matt
« Reply #12 on: September 27, 2011, 09:35:02 AM »
I have only seen one transom poured and i was not too impressed. I would build it from coosa board or marine plywood layered with biaxle then tab it in.
Capt Matt
Light tackle sportfishing
September 27, 2011, 09:49:48 AM
« Reply #13 on: September 27, 2011, 09:49:48 AM »
Here's a start. Search is your friend.
http://classicaquasport.com/smf/index.php?topic=7063.0
Follow the links.  :ScrChin:
September 27, 2011, 05:00:58 PM
Curious
« Reply #14 on: September 27, 2011, 05:00:58 PM »
Well, I've done a little more research and here's what I think I'm going to do.  I'll cut the rear skin off the transom, leaving about 4 inches or so around the sides and bottom like this:
It'll make it that much easier to dig out all the rotten wood and get it clean and dry.  Then reattach and brace like this:
And then do the pour.  It seems like an extra step but I don't think I'll get it as clean by just accessing through the top cap.
Next question, if I go to all this trouble, should I drill into the rear of the stringer while I have the back end opened up and see if the foam is wet?  I'm a lot more comfortable now knowing that the stringer is glassed in seperate from the transom, but I feel like I should do some exploratory surgery while I have access.
Dan
