I'm creating an anchor locker at the bow. I've had a similar set up on another boat and liked it. Room for anchor, lines and bumpers, and keep the anchor secure. See pic here showing new wall. I'll need a secure and strong hatch on cap. Good luck. BTW -- I'm also restoring a '74, 22-2, V-hull.
The CCPs have an anchor locker in the bow.
Quote from: "GoneFission"The CCPs have an anchor locker in the bow. The thing I didn't like on mine was that you can't close the hatch cover (pretty, slatted teak from the factory) unless you have all of the rode on deck. I ended up mounting anchor chalks/cleats on the upper front deck and ran the line through a hawsepipe back into the locker. In it's heyday, we used the CCP for a lot of diving and that setup made it easy for any landlubber to deploy or retrieve the anchor and saved having to replace hinges on the cover. It stayed closed and latched most of the time. -6 on form for sure but a +10 on function.
