Author Topic: 17 Motor & Draft"?  (Read 1288 times)
September 22, 2011, 07:20:47 AM
Read 1288 times
HIFLUTIN
17 Motor & Draft"?
« on: September 22, 2011, 07:20:47 AM »
17 Motor & Draft"?
What draft" can I expect with a 17 & 90hp
Have not had mine in the water so I don,t have a clue?
Draft" as in floating not on plane
September 22, 2011, 08:27:07 AM
MarshMarlowe196
Re: 17 Motor & Draft"?
« Reply #1 on: September 22, 2011, 08:27:07 AM »
Depends on the 90HP motor... 4 cylinder?  3 cylinder?
Generally speaking, expect about 8-10"
Key West 1720 / Yam C90
Sold: 1973 Aquasport 19-6
September 22, 2011, 12:06:23 PM
c master
« Reply #2 on: September 22, 2011, 12:06:23 PM »
I have a 170 with a Johnson 88 spl.  I believe the bottom of the skeg is more than 10" below the hull though, so I'm guessing that 'at rest' the total draft is going to be closer to 18".  Shallower on plane of course.
I'll measure for you.  The cavitation plate is in the correct location and my transom drains sit just above the waterline.
C Master
1975 Aquasport 170
file:///C:/Users/cliff.haehl/AppData/Local/Temp/IMG_0135.jpg
September 22, 2011, 08:35:04 PM
akbridge
« Reply #3 on: September 22, 2011, 08:35:04 PM »
I think my boat draws 8" empty.  When I have a full load it gets closer to 12".  I have a jackplate on my boat so I can run with the prop center line about even with bottom of the hull.  On a good day I might be able to run in 9" of water for a short run.  I know I have crossed shallows near Pine Island that were 18" deep.  EZPZ.
September 26, 2011, 10:36:04 AM
c master
« Reply #4 on: September 26, 2011, 10:36:04 AM »
akbridge - how far from c/l of your prop, to the bottom of your skeg?
C Master
1975 Aquasport 170
