Author Topic: leaning post pics and suggestions?  (Read 1087 times)
February 16, 2006, 05:55:52 PM
Read 1087 times
ddd222
« on: February 16, 2006, 05:55:52 PM »
hi guys, looking to change from the old seats to a leaning post, had a good oppurtunity from an older 21' mako, that would slide on existings pedestals, but someone else beat me to it. Would not like to spend the scratch for a custom one, and also concerned about the footprint left from old stantions if those come out. Can any of you show me or explain what you did faced with the same situation? Not replacing deck and starting from scratch so thats not an option, thanks in advance guys!
February 17, 2006, 03:03:44 AM
steved
« Reply #1 on: February 17, 2006, 03:03:44 AM »
I'm facing the exact same situation.  My decision so far has been to wait until another opportunity comes along, or maybe to work something up myself by using the seat bases and a padded crossbar of some kind to be the leaning post.  I agree with you about not wanting to mess with removing the original suports from the deck.
22.2 CCP (1982)
February 18, 2006, 10:44:58 AM
Tailgunner
    • http://nbrigham.com/Nix/nix.html
« Reply #2 on: February 18, 2006, 10:44:58 AM »
I know you guys are in a different situation than me but I'd thought I'd share.
I'm in the process of building one from scratch. Since I'm not a welder and I don't have much scratch, I'm going with a 3 sided fiberglass style. I'll design the rear opening to accept my 20gallon live well.
I figure two sheets of 1/2" MDO and some fiberglass should do it. I won't be doing anything as fancy as the Todd, just 3 sides and rod holders in the top. The hardest part is finding a pre-made pad for a reasonable amount of money. I can design the top to fit the pad.
Tailgunner
Now in BroadBill\'s hands
February 19, 2006, 10:29:04 AM
sandbarbilly
« Reply #3 on: February 19, 2006, 10:29:04 AM »
Hey Tailgunner, it's not that hard to make your own cushion. Build a plywood back that you can install bolts or those wood nuts that lock into the wood. Glue some foam padding on it. Stretch over some marine fabric (readily available with the pleats already molded in) and staple to the back of the plywood. You'll end up with a few "hospital corners" like when you tuck in the sheets on your bed. Or you should be able to find a little old lady with a sewing machine to stitch it up and then just silicone the back of the seams.
February 19, 2006, 10:38:38 AM
sandbarbilly
« Reply #4 on: February 19, 2006, 10:38:38 AM »
Hey ddd222, I thought long and hard about doing the exact same thing. Todd makes an adjustable leaning post that fits over the seat posts. I don't think it measured up to fit mine. But you could build a basic flat top leaning post with rod holders mounted, maybe a drop down in front with a pad. Then just mount standard seat spiders on the bottom to fit your seat post measurements. You'll have to mess with the height a little. Some aluminum tubing of the correct I.D:O.D. and a little "FIGURIN" should do it. You should be able to slide it right off and slide the seats back on. Over the years I've seen two tops on Ebay that would have given you a good start. One was mahogany the other was starboard.
February 19, 2006, 07:16:43 PM
ddd222
« Reply #5 on: February 19, 2006, 07:16:43 PM »
thanks for the info guys, keep it coming!
February 19, 2006, 11:02:56 PM
warthog5
« Reply #6 on: February 19, 2006, 11:02:56 PM »
Tailgunner  It still wouldn't be a bad idea to incorporate some fire Ext box's in the side's.
February 20, 2006, 09:39:10 AM
Tailgunner
« Reply #7 on: February 20, 2006, 09:39:10 AM »
Quote from: "warthog5"
I have the fire extinguisher in the console. I was thinking of incorporating plano tackle boxes in the leaning post.
Tailgunner
