Author Topic: gauges  (Read 1714 times)
September 13, 2011, 01:47:09 PM
Read 1714 times
stuart725
gauges
« on: September 13, 2011, 01:47:09 PM »
This year i put my 92 wac aquasport in the water and noticed that the gauges didn't work . I was wondering if anyone would know where i can buy two more . They are the digitial ones , which would lead to my next question should replace them with individual gauges ( fuel , speed , tach etc ). Which one should I go with    :roll:
September 13, 2011, 01:50:34 PM
Re: gauges
« Reply #1 on: September 13, 2011, 01:50:34 PM »
Quote from: "stuart725"
"Digital" as in Yamaha round digital gauges? :?
September 13, 2011, 01:57:09 PM
stuart725
Re: gauges
« Reply #2 on: September 13, 2011, 01:57:09 PM »
Yes the ones that do the fuel and two other things too
September 13, 2011, 02:10:30 PM
Re: gauges
« Reply #3 on: September 13, 2011, 02:10:30 PM »
either Ebay or call The marine connection in Ft. Pierce, they have all the Yami stuff and good prices, although none of them are cheap, it's way below retail.  The other thing with buying used without testing first is, sometimes the Yami digital guages look fine, but when powered up, or after being being powered up for a while, the LCD will start to fade or blank out like the old LCD watches, where an "8" would like like a "9" because one of the lines is missing.
http://themarineconnection.net/Gauges.html
September 13, 2011, 02:17:32 PM
stuart725
Re: gauges
« Reply #4 on: September 13, 2011, 02:17:32 PM »
Thanks looks good !!!! :salut:
September 13, 2011, 02:48:18 PM
Re: gauges
« Reply #5 on: September 13, 2011, 02:48:18 PM »
Let me ask this.
Neither gauge works at all, yet the motor cranks and starts correct?
September 13, 2011, 02:49:28 PM
Re: gauges
« Reply #6 on: September 13, 2011, 02:49:28 PM »
Marc is dead on.  Older Yam gauges, the LCD screen will discolor to the point where you can't read them anymore...the gauges actually work, but.  And there is no way of fixing them.
Be prepared for a little sticker shock.  New replacements will run $300-400 per gauge...
September 13, 2011, 02:50:42 PM
Re: gauges
« Reply #7 on: September 13, 2011, 02:50:42 PM »
CB,
I've run into this several times over the last couple of years.  It's inherant with the Yam digitals, ESPECIALLY those without some protection from the sun...
September 13, 2011, 03:20:09 PM
stuart725
Re: gauges
« Reply #8 on: September 13, 2011, 03:20:09 PM »
So what I should do is buy two new gauges and hope for the best . Any other good places to buy the gauges other then the other one listed ? :D
September 13, 2011, 04:14:42 PM
Re: gauges
« Reply #9 on: September 13, 2011, 04:14:42 PM »
If you buy new, you'll be fine.  Try Pelican Marine, heard they have a pretty "fair" deal when you buy both the tach and the speedo...http://www.pelicanmarinecenter.com/
September 13, 2011, 08:53:44 PM
Re: gauges
« Reply #10 on: September 13, 2011, 08:53:44 PM »
92 WAC eh.
I want to see a pic of the boat. :thumleft:
PS... My gauges are yellow as can be from the sun. Fortunately, the LCD screens still work but I had priced new gauges just in case. I keep a towel over mine when I'm not actually underway. They need to last a little longer, at least to 2012. :roll:
Sticker shock is saying it nicely. :shock: but then SB always had a way with words. :wink:
September 13, 2011, 10:44:46 PM
Re: gauges
« Reply #11 on: September 13, 2011, 10:44:46 PM »
As I posted on here last year, when I switched over to the Yami Fuel Management guage/system, I bought the brand new in the box, guage, wiring harness and fuel transducer from MCL in Ft Perce for $299.  I called my local Yamaha dealer friend from MCL, and asked him what he could give me for a "good deal"...  around $800 retail, and he said he could make it a little better for me?  He said $300 is more than a steal.  Now I don't know what their prices on the tach and speedo are?  But it's worth a phone call, and since you are inquiring about a specific item/s, they know exactly what they have and the price, unlike panels, hatches etc... that they really can't ID for you unless ou have a sample to match with.
September 14, 2011, 10:51:56 AM
stuart725
Re: gauges
« Reply #12 on: September 14, 2011, 10:51:56 AM »
You guys are the best !!!! I don't care what those Grady White owners say ? No just kidding but thanks for the help and i will be buying new ones soon . Maybe you guys can answer another question too , when i'm going at cruising speed sometimes the motor cuts slows down . It seems as thought there is a lack of fuel , but it will pick up and go again , but never stalls or dies . does this sound as if there is a fuel pump problem ,leak,carb problem and i also heard that the older fuel lines don't like the newer fuel ? Any suggestions  :?  P.S going to get boat out of water this friday so i will post some pictures then it is a sweet ride !
September 14, 2011, 12:30:23 PM
Re: gauges
« Reply #13 on: September 14, 2011, 12:30:23 PM »
Stuart, as mentioned previously, I don't think you have told us what engine you have?? If you have a newer DFI/EFI yamaha, the filter/S could definitely be a problem, they will cause surging and loss of power.  But we gotta know what's hangin on the transom.
September 14, 2011, 12:42:37 PM
stuart725
Re: gauges
« Reply #14 on: September 14, 2011, 12:42:37 PM »
Sorry about that ,it's a 92 Yamaha 200 hp . It starts and runs mint , but then sometimes when you are going faster it will basically cut back to an idle while still going ?
