Author Topic: Motor Shaft Length  (Read 923 times)
September 08, 2011, 03:26:51 PM
Read 923 times
riverrunner
Motor Shaft Length
« on: September 08, 2011, 03:26:51 PM »
I have a 17', so I know it is a 20" shaft, but does the 19' also take a 20" shaft?
September 08, 2011, 03:39:14 PM
Re: Motor Shaft Length
« Reply #1 on: September 08, 2011, 03:39:14 PM »
Yes.  You don't start getting into 25" shafts until you see deep vees...
September 08, 2011, 04:23:07 PM
riverrunner
« Reply #2 on: September 08, 2011, 04:23:07 PM »
Thank you bob. I forgot to mention that it was a 1973. I didn't think any of the CC's from the 70's used 25" shafts, but I have been wrong before. I'm looking at a 19 (pic), and I would put the motor on another hull, and then redo and re-power. But the other hull definitely takes a 20" shaft motor.
September 09, 2011, 09:49:58 AM
« Reply #3 on: September 09, 2011, 09:49:58 AM »
The 222s generally have had 25" transoms, at least from the late 1970s, but the 20 footers on down have been 20" transom height.  As Bob said, all the deep-V outboard hulls have 25" transoms.
September 09, 2011, 11:47:21 AM
« Reply #4 on: September 09, 2011, 11:47:21 AM »
Yep the 19's are 20 inch.
My 1983 222 has a 25" transom with the 12 degree deadrise.
