Author Topic: Newbie Floor paint?  (Read 915 times)
September 08, 2011, 06:50:20 AM
Read 915 times
HIFLUTIN
Newbie Floor paint?
« on: September 08, 2011, 06:50:20 AM »
Newbie Floor paint?
After looking for a awhile Finially found a Early 80's 17 in decent shape.
Transom & floor are in good, needs some overall cosemetic work etc.
? on floor paint.
The floor/deck has been painted, the paint is older & faded etc.
Would like to re-paint but have a concern with sanding (for the new paint to stick) with out damaging the existing diamond non skid surface.
Any suggest?
September 08, 2011, 07:05:33 AM
Blue Agave
Re: Newbie Floor paint?
« Reply #1 on: September 08, 2011, 07:05:33 AM »
Welcome HIFLUTIN.....Thats a tuff one, if you re-gel or repaint the floor kiss the diamond non-skid goodbye.  You will have to re-apply a new non-skid coat.  The most typical, is a uniform non-skid across the whole floor and or deck cap.  Depending on your budget and or skill set you can have a patterned non-skid deck.  When I did my floor, we used half inch tape running from bow to stern with a two inch gap between each strip of tape.  My deck has smooth half inch stripes running from bow to stern like the old Sea Crafts, looks real sharp.
I'm sure others will chim in with ideas and tips.  Good luck!
1975 19-6
3.0 EFI Mercury 150 4S
September 08, 2011, 07:27:28 AM
« Reply #2 on: September 08, 2011, 07:27:28 AM »
Quote from: "Blue Agave"
Welcome HIFLUTIN.....Thats a tuff one, if you re-gel or repaint the floor kiss the diamond non-skid goodbye.  You will have to re-apply a new non-skid coat.  The most typical, is a uniform non-skid across the whole floor and or deck cap.  Depending on your budget and or skill set you can have a patterned non-skid deck.  When I did my floor, we used half inch tape running from bow to stern with a two inche gap between each strip of tape.  My deck has smooth half inch stripes running from bow to stern like the old Sea Crafts, looks real sharp.
Lose the original non-skid if it's that bad, once you get the new stuff down like Blue said, you will be impressed, JD Dupree used some stuff (I can't remember the name) that looked awesome when done.
September 08, 2011, 07:54:07 AM
« Reply #3 on: September 08, 2011, 07:54:07 AM »
Check out Kiwi-grip, the stuff is awesome.  Easy to apply, no mess... no other choice IMHO.
September 08, 2011, 08:56:20 AM
« Reply #4 on: September 08, 2011, 08:56:20 AM »
Marc, the stuff JD used was called Durabak. It turned out real nice. Supposed to be very similar to Kiwigrip.
September 08, 2011, 01:14:47 PM
« Reply #5 on: September 08, 2011, 01:14:47 PM »
Yup - that stuff is even more "Sticky" I here... also a good choice.
September 08, 2011, 01:51:35 PM
Capt Matt
« Reply #6 on: September 08, 2011, 01:51:35 PM »
used Kiwi grip on mine, easy to apply and you can make it as rough as needed.
Be sure to get the textured roller to apply it
Capt Matt
Light tackle sportfishing
September 08, 2011, 02:19:20 PM
HIFLUTIN
« Reply #7 on: September 08, 2011, 02:19:20 PM »
Wow Guys thanks for the input.
How is the clean-up (Fish Blood etc) on the Durabak etc?
September 08, 2011, 07:11:51 PM
« Reply #8 on: September 08, 2011, 07:11:51 PM »
Can't respond to Durabak, but with Kiwi grip it's easy.  I've had it down over three years, and it's just starting to show minor stains / wear.
