Author Topic: Fletch's 1976 170 Rebuild  (Read 22855 times)
May 08, 2013, 10:12:23 AM
Reply #375
Georgie
Re: Fletch's 1976 170 Rebuild
« Reply #375 on: May 08, 2013, 10:12:23 AM »
X2
That's exactly what I did. :salut:
Ryan
1979 246 CCC
1987 Wellcraft 18 Fisherman
May 10, 2013, 10:05:38 AM
Reply #376
johnnyred_1999
« Reply #376 on: May 10, 2013, 10:05:38 AM »
That should do it, as long as the ground wire is grounded properly you should be in good shape. Just need to dissipate the static electricity.
June 19, 2013, 01:16:41 PM
Reply #377
Fletch170
« Reply #377 on: June 19, 2013, 01:16:41 PM »
Hey all. Got a few pictures from the works ive done over the last month. She is running and ready to hit the water! I'm putting her in this weekend for her maiden voyage. Just need to Install the leaning post. I'm pumped.
Here are a few pictures!
http://fletch170.blogspot.com/
1981 2100 CC Hydra Sport
1976 170 (sold)
June 19, 2013, 04:18:18 PM
Reply #378
« Reply #378 on: June 19, 2013, 04:18:18 PM »
Fletch,
The best thing about this thread is that you did everything yourself and really had (by your own admittance) not a lot of rebuild experience. Boat looks great and you learned a great deal about restoration/rebuilding/rigging.
That deserves a  :salut:
Enjoy.
June 19, 2013, 04:41:52 PM
Reply #379
« Reply #379 on: June 19, 2013, 04:41:52 PM »
AMEN!!!!
Gorgeous job :cheers:  :cheers:
June 19, 2013, 06:20:05 PM
Reply #380
« Reply #380 on: June 19, 2013, 06:20:05 PM »
Looking good  :salut:
June 19, 2013, 08:49:43 PM
Reply #381
« Reply #381 on: June 19, 2013, 08:49:43 PM »
Looks good, and I bet your are feeling good too!  I can't wait for the feeling when my rebuild crosses the finish line.  Although that is a long way off....
June 19, 2013, 09:30:47 PM
Reply #382
« Reply #382 on: June 19, 2013, 09:30:47 PM »
Great accomplishments take time. A finished product gives satisfaction and closure....
But the thrill is in the hunt :thumright:
June 19, 2013, 11:21:40 PM
Reply #383
gman 82 aquasport
« Reply #383 on: June 19, 2013, 11:21:40 PM »
She looks great :salut: , know your thrilled about splashing her...Job well done, best thing is if anything ever goes amiss you will know where to look and how to get to it because you did it :thumright: like the look of all the interior lights to..
1982 19-6 Osprey
1992 Johnson 150
"THERAPY"
Member # 2331
June 21, 2013, 10:56:06 AM
Reply #384
Fletch170
« Reply #384 on: June 21, 2013, 10:56:06 AM »
Thanks guys, It's been a really long, itchy, expensive and tiring process....but I did learn a lot.
Took some additional pictures after I tuned the motor, I'll follow up with pictures on the water this weekend.
1976 170 (sold)
June 21, 2013, 11:00:50 AM
Reply #385
« Reply #385 on: June 21, 2013, 11:00:50 AM »
 :cheers:  :cheers:
June 21, 2013, 01:16:27 PM
Reply #386
« Reply #386 on: June 21, 2013, 01:16:27 PM »
Fletch,
Will you be adding any graphics/striping/name to your project?
June 21, 2013, 01:58:50 PM
Reply #387
Fletch170
« Reply #387 on: June 21, 2013, 01:58:50 PM »
At this point, I'm planning on simply marking the waterline and bottom painting the hull sides and transom accordingly.
As you might notice, I'm a minimalist. Stickers and graphics aren't my thing. I don't even think im going to put a name on the side, as I think it will make the freeboard look even smaller.
The Name of the boat is "SeaBooies".
We have a American Bulldog, we started calling her Bully, then boos, then booies. She loves boats.  Since its somewhat a play on the word "Buoys". We are naming it SeaBooies.
It's that or "Soggy Dollars". Not 100% yet.
1976 170 (sold)
June 21, 2013, 04:22:13 PM
Reply #388
dburr
« Reply #388 on: June 21, 2013, 04:22:13 PM »
Quote from: "Fletch170"
 :alien:
GOTTA love that!!! DOGS Rule!!
Outstanding progress and man does she look NICE!  :salut:
A great warmup for a 222 :mrgreen:
Dave
88 222 Osprey
00 Yamaha OX66 150
CAS # 2590
June 24, 2013, 08:45:08 AM
Reply #389
Fletch170
« Reply #389 on: June 24, 2013, 08:45:08 AM »
YO GUYS! PICTURES OF THE BOAT ON THE WATER!!!!!!!!!!!
Launching and trials went off without a hitch! She ran really well. 2 Guys, full of fuel, light chop, she did 42 MPH on the GPS. I'm guessing with just me, light on fuel and trimmed up, she'll do 45-46. Frankly, 42 MPH on that little thing was plenty fast enough.
The only 3 things I need to work out (please feel free to insert opinnions here) is that it has a rough idle, and the lower unit has somewhat of a high pitch hum, almost harmonic sounding, and lastly, I'm not sure if the thermostat is working, as it might be stuck open.
The motor runs awesome 1/3 and up in the throttle, it just feels like it's running on 3 of 4 when idling and low RPM. This only happens when the motor is under load. The throttle response is awesome, and she starts right up.
The sound I'm hearing from the lower end sounds like harmonic vibrations through metal (if that makes sense). It only seems to be happening at certain RPM's.
The temp really never seems to be getting up there. If I recall, on these 2 stroke motors, after a while, the sea water expelled from the motor is usually luke warm when the motor is warmed up. In my case, this never happened, it's basically cool as the bay water. This made me concerned, so I took off the cowl, and after running for 40 minutes, the heads were room temp, and the block was barely "warm" to the touch. Furthermore, after running for some time, she still smoked when coming to a low RPM. This is what is leading me to believe the thermostat is stuck wide open. Thoughts?
1976 170 (sold)
