Crap.......I was hoping to use the 2ga battery cable to connect the switch to the bus terminal. Thats overkill on the #2 wire feeding the positive buss. I guess you did that b/c you had extra..?? #10 is all you need to handle all the accessories. SO, you are suggesting that I use 10ga wire from the battery switch, with a 30a inline fuse right next to the switch. From there I will run the 10 Gage right to the fuse/ switch pannel? The only thing hot wired directly to the battery would be the "Auto" position to the bilge pump?Let me play Devil's advocate here:Assuming I'm running 2ga battery cable to a bus terminal, what is preventing me from putting the fuse inline near the bus on the way to the switch pannel? There is no way the acessories could burn up a 2ga wire or a bus, right?You are right. No way you could overload the #2 cable. It's just not "common practise". You could put an inline fuse holder on the wire feeding the fuse panel. #12 wire is plenty.Also, the feed into the fuse pannel/ switch pannel is 14ga, and will only accept that size. So, wouldn't fusing 10ga with 14 just negate the 10 all together as that small section of 14 is still under load?
So then, as you are the equivalent to a boat wiring Jesus, is what I'm doing OK? Running 2 feet of 2GA to bus, then 14 ga fused (Close to the bus), to the pannel? Or should I really consider something different. I just dont wanna be a mile off punching my own head to put the flames out, wishing I did something different.
Excellent work, Kraw! I love "clean", and that is VERY clean!!
Quote from: "seabob4"Excellent work, Kraw! I love "clean", and that is VERY clean!! Thank you but the bigle cover is crooked..!!!
