Hey Everyone! Looks like I did the damn near impossible. Figured a way to run all my rigging under the deck of a 170. The one larger tube has a "S" type bend of 2 large 90's. I was worried that the throttle might bind, but I put the cables through the assembled tube and they worked perfectly. The only thing I forgot to do was drill drain holes in the smaller ones, so that any water can drain out.Here's the link to the new pics! http://fletch170.blogspot.com/One question. All of the tubes come up inside the console, and it's going to look like hell. How did you guys dress this up? Is there a larger "boot" available, similiar to what you see offten times in the stern where the motor's rigging is fed through? (terrible description, I know).Any help would be greatly appreciated!-Christian
Hey,I could do the 30 degree entry from the outside of the stringer. The problem still stands, there is a 90 degree bend that goes up. The 30 degree would help though. We'll see, I'll plumb the shift cables and see if it binds. if it does, I'll just cut the stringers up even more! YAYYYYYYYYYY. Glassing back all the holes before I pour the foam should be a real treat.
