Quote from: "DOCREED"It coast him 6K if i remember correctly.do you remember if his tank was poly or alum? also, what size?so far, I'm into this project:$1400 = tank (alum ~130 gals)$100 = parts (plastic, rubber strips, shop supplies, etc)I still haven't purchased:1) the new SS Hardware I'll be using yet when i put everything back together2) the fiberglass/resin/gelcoat 3) shipping for the tankI'll try to post a total of costs when I'm done.
But the big cost was to remove the entire deck moulding to get to the tank without cutting.
My 99 Osprey 245 TM has a poly tank...when I popped the pie plate behind the council to access some wiring a while back....I saw no/minimal water intrusion in the tank compartment...(I feel very lucky right now)...I did replace all the o-rings on all the Rabud pie plates ....they were getting a little hard.
3" Wide ABS Plastic, 1/2" High. There are four 3' strips under the tank (2 on each side of the tank).Next step is to take the boat to an aluminum fab shop here.I'm having them:1) create new straps for the tank (really, more like brackets) to hold it down (2 of these)2) create some custom cross-braces made out of aluminum ladder rungs that will be used to help support the floor over the tank (3 of these)
Why did you choose not to 5200 the plastic strips to the inside of the coffin or is there not really a based to glue to?
I'll shortly be looking at a new tank myself. Can someone tell me what are the advantages of a poly tank vs. aluminum? Where can you buy poly tanks?Many thanks!
So why buy aluminum? To get the tank that is the right size for your fuel compartment.
