Take the whole backing plate out and use a blow dryer to help get as much moisture out as you can. Check the condition of the wood around the hole and if its soft gouge it out as best you can. If its really soft overdrill the hole and clean out all soft or damp material. You might need to go with a holesaw as big as 2 1/2". Then get some clear packing tape. Pull out two strips of the tape and lay them side by side with the glue side up. these pieces only need to be about 6 or 7 inches long. Pull off another piece of tape just long enough to cover the other two perpendicular to them and lay it on sticky side to sticky side.Add another strip beside the first so you have a square of slick tape with the sticky on the inside and a little glue on each side. Mix up some epoxy, just enough to fill the hole and coat the inside of the hole using the epoxy as a primer. Then add Cabosil to thicken and a little milled fiber for strength. Mix this up until it is thick like cold peanut butter. Wipe this into the "primed" hole and try to work any air out. If you can get to the inside tape it off using the slick patch you made and use duct tape to hold it in place. Once the hole is filled and you have it as smooth as you can get it take another of the slick patches and mash it onto the surface of the epoxy. Smooth it out as best you can and work any air out from under it. Then tape it into place as well with the duct tape. The packing tape will stick to the epoxy while it is uncured but give it 24 hours and remove the patches and you end up with a nice slick repair that is impervious to water and it ill be ready to drill and put the backing plate and plug back in.Or.... you can do what Fitz said!!!!!
Hello gentlemenrecently picked up a 81 20 ft walk around and noticed the transom drain was loose, pulled the brass plate and there was no sleeve in drain and wood is wet, it seems there is about an 1/8 inch space between the plywood layers in the hole, hull is solid with spider cracks on port side. should I be concerned or just resleeve, 5200 it and be done??Thanks :bounce:
