Author Topic: Bow Mounted Trolling motor on 22-2?  (Read 1437 times)
August 28, 2011, 11:26:10 AM
Read 1437 times
snookman
« on: August 28, 2011, 11:26:10 AM »
Is it possible to use a bow mounted trolling motor on a 22-2 Flatback, 22-2 Semi-v or 24ft Pro-line Flat back?
Is the bow rise too high?
Has anyone had any expierenced with this application?
Albert.
August 28, 2011, 11:29:40 AM
Re: Bow Mounted Trolling motor on 22-2?
« Reply #1 on: August 28, 2011, 11:29:40 AM »
Check out some of these threads:
viewtopic.php?f=1&t=4534&p=28662&hilit=trolling+motor#p28662
viewtopic.php?p=28662#p28662
viewtopic.php?p=31988#p31988
Good luck!
August 28, 2011, 11:31:49 AM
snookman
« Reply #2 on: August 28, 2011, 11:31:49 AM »
wow that was quick,
How do I access those threads?
there are no links to them?
August 28, 2011, 11:35:34 AM
August 28, 2011, 06:45:13 PM
14cwater
« Reply #4 on: August 28, 2011, 06:45:13 PM »
In my opinion it is a waste of time to try to bow mount a trolling motor on a 22-2  I have a flatback and tried the bowmount 24 volt trolling motor with the longest shaft min-kota make and if you are fishing in any kind of chop the motor wants to come out of the water.  On the other hand if it is calm out they work great.  Just my 2 cents
August 28, 2011, 08:02:55 PM
« Reply #5 on: August 28, 2011, 08:02:55 PM »
heres my trolling motor:
http://classicaquasport.com/smf/index.php?topic=7015.0
36volt motorguide, only way to go on anything over 20 ft
August 29, 2011, 01:13:54 PM
Capt Matt
« Reply #6 on: August 29, 2011, 01:13:54 PM »
Anyone hear about a cavitation plate for a trolling motor?  Another option is to custom order a 70 inch shaft trolling motor. I'm gonna need a bow mount trolling motor for my flatback soon and am looking at all the options. My guide buddy has a 23 dorado (22-2 copy) with a bow mount 60inch shaft that works pretty well. Is that boats bow lower than by flatback bow?
Capt Matt
Light tackle sportfishing
