Author Topic: electric issues, overhead lights  (Read 914 times)
August 22, 2011, 02:53:38 PM
Read 914 times
wpt03osprey
« on: August 22, 2011, 02:53:38 PM »
2003 Aquasport Osprey T top
I have 2 overhead lights on this boat that are wired into dash on toggle switch with re-settable circuit breaker.
These light stay on for 4-5 minutes then trip breaker, after cooling a while it will work again for another 4-5 minutes.
any ideas , a short , or too small a breaker for these lights
Just a Hacker
2003  Aquasport 250 Osprey
August 22, 2011, 04:39:51 PM
Re: electric issues, overhead lights
« Reply #1 on: August 22, 2011, 04:39:51 PM »
What wattage are ya runnin'?  Two 55 watt bulbs may be too much - if you are running high watt bulbs, switch to LEDs and your current will go way down.
August 22, 2011, 04:59:14 PM
« Reply #2 on: August 22, 2011, 04:59:14 PM »
The standard breaker that the lights run off of (ACC switch) was a 10A.  On T/Top boats, I switched it out to a 15...
But ScarabChris's LEDs, which are awesome?  Both lights won't even draw 2As...
August 22, 2011, 09:26:31 PM
« Reply #3 on: August 22, 2011, 09:26:31 PM »
Here's what one can do on a 28 Pursuit...1 spreader!
August 22, 2011, 10:49:03 PM
« Reply #4 on: August 22, 2011, 10:49:03 PM »
had the same problem with my spreader lights,put a larger breaker in :cheers:
August 22, 2011, 11:44:46 PM
« Reply #5 on: August 22, 2011, 11:44:46 PM »
That's what you want. High output...low draw.
August 23, 2011, 03:17:02 PM
« Reply #6 on: August 23, 2011, 03:17:02 PM »
Chris' lights look good also.  Here's the pair I installed on a H-S 22WA on the arch...
And the look they gave at night...
Ran them both using a 5A breaker...
August 23, 2011, 04:49:44 PM
« Reply #7 on: August 23, 2011, 04:49:44 PM »
fully agree on the LEDs, they are the way to go.  However, if this tripping is something that has just recently started on the lights, that previously worked ok, find the butt connectors where they were spliced in, and you'll probably find green corrosion, creating a high resistance and thus a higher load on the circuit, and tripping the already borderline capacity breaker.  Just a thought
August 23, 2011, 06:44:19 PM
« Reply #8 on: August 23, 2011, 06:44:19 PM »
August 23, 2011, 10:19:20 PM
« Reply #9 on: August 23, 2011, 10:19:20 PM »
Mark,you are probly right! :cheers:
