Author Topic: 1974 170 Parts and Advice  (Read 799 times)
August 18, 2011, 01:16:15 PM
Read 799 times
daniel123
« on: August 18, 2011, 01:16:15 PM »
I have a 1974 170 I am updating and am looking for a raised letter Aquasport medallion for the aft/outside of the hull. One of mine is good; the other is part torn away. If those are no longer available, or I just can't find one, what Aquasport logo/decal decal would be most appropriate for that year/model? There are several after-market decals on E-bay but they come in several sizes and appear to be designed as copies for newer A-sports. I also would be interested in seeing any 1970s-vintage parts that might be available that would make the boat closer to original as well -- such as the anchor locker hatch? Mine is plain flat teak ply; is that original?  I removed the bow rail and have that available, and also wonder if any one has a source for a dodger that would fit a 17.
One final question: My boat has plenty of hairline cracks, outright holes and chips (small) in the white gelcoat layer showing darker glass underneath and places where holes have been drilled for mounting stuff, some filled with filler and some not. For my part, I have all the holes from the bow rail hardware I removed that I have filled with epoxy but need to refill to make flush and cover cosmetically somehow. Other than a complete Imron job, what are my alternatives to make the boat's finish look as good as possible? As for the the deck/floor,which is original with the green color, can it be repainted and still maintain the skid-free texture? If so, what paint and color code should I use?
Thanks, guys. This is a great resource and just sort of fun to read through.
Dan
614-431-0071
August 18, 2011, 04:05:39 PM
Re: 1974 170 Parts and Advice
« Reply #1 on: August 18, 2011, 04:05:39 PM »
Here's a start on deck paint. Read through the thread and you can then decide if this is what you're looking for.
Tough finding the original green tint I would think.
viewtopic.php?p=49777#p49777
August 19, 2011, 12:55:03 PM
c master
« Reply #2 on: August 19, 2011, 12:55:03 PM »
I have a '75 170.  I believe these are very similar boats.  Here are some thoughts and remember, they are worth exactly what you paid!  (meaning, they might be worthless)
Sounds like our hulls (and personal preferences) are similar.  I'm a purist, and I would love to Awlgrip my boat. But it's incredibly expensive.  I keep reminding myself that if I was going to spend that kind of money on paint, a new 4-stroke, etc, I might as well find an old 22-2 and have a bigger, refurbished boat that makes sense to have $25,000+ invested.  Although I just bought a new aluminum trailer...that feels pretty good.  (Peace of mind, easy loading, classy, etc)  But can I justify it?  Hmmmm....ask my bride.
Anyway, regarding:
* Anchor hatch:  I believe they were teak originally.  If you reach inside, you'll find there is some structure around the oddly shaped opening...but it shouldn't be hard to reproduce a teak one.
* Aquasport raised logo:  I know it's expensive but if an "original" hard plastic logo is important to you, the only way might be to find a graphics/signage company and get them to cut one out.  They're beveled so get ready for $$$.  Or, match one in vinyl.  Not long ago, there was someone on this site who could produce them...I think there's a 'string' about it.   Take a look at Calusa Wind...his logo is vinyl (not original) and looks great...along with the every other detail of that boat.
* Floor.   They are very 'paintable' with epoxy, although you will find that it's a LOT of work, moving the console, removing hatches, etc.  And then you're gonna want to paint the hull - it's a slippery slope!  So I cleaned my floor with a good color-restoring fiberglas cleaner, then rubbed Penetrol on it.  After it's dry, the Penetrol isn't slippery and it looks pretty good.  I did the same thing to the hull inside and out (cleaning/waxing/buffing...not Penetrol)   Scrubbed the rub-rail with BonAmi...it improved.  Oxalic acid for the brown water-stain I get after a few days in the water.
* filling holes & chips:  I experimented with adding off-white color to gel coat, until I found a blend that was very close to the hull color.  This is easier said than done...I had a hard time with the underside of the hull.   Here in Houston I know some excellent fiberglas guys - it's a lot more expensive but their work is just so much better than my own.
*  Hairline cracks...for the most part, I don't worry about them.  Awlgrip will cover all of that but again, only you can decide if it's worth the money.   For me, new wiring is my next effort.    C
C Master
1975 Aquasport 170
file:///C:/Users/cliff.haehl/AppData/Local/Temp/IMG_0135.jpg
