k pulled the gear case earlier this past week to do water pump change it was dry and i seen no signs of any possibles leakage of any kind so that should rule out that seal i was planning on a compression test today sometime i have to go borrow a friends compression tester some body needed mine more than i did lol. a standard automotive tester is fine with these 2 strokes right just making sure.
