T...For 3-6 nights, this might slow your cruise speed down a bit, but..... :rabbit: Have a good weekend.Marc
T,Keep in mind, well placed marinas with a comfy hotel/motel/cabin midway through the cruise can do wonders on the Admiral...
Honda e2000i generator2 - 1gal no-spill containers of gasWindow shaker Air Conditioner to put in doorway - build fill in "dam" for rest of doorway - generator will run AC for 7 hours on 1 gal of gas.18" 12v box fan
Rick, Can you tell me more about this AC unit? Is the manufacturer called Window Shaker? Where did you buy it? Does it work well? Thanks for all your help and advise, you're a good ship mate, T
Actually, something like this works pretty well on a smaller boat (less than 30 feet). You just duct the hot air out through an open port. Some boats have ports that almost match the duct size... These usually draw around 12 amps, so they will run on a 2000 watt generator, but you won't be running much else... http://www.walmart.com/ip/KuulAire-12-0 ... r/16621164
- plus people said they kinda missed the hum when they were sleeping
