Author Topic: 225 Freshwater system  (Read 453 times)
July 30, 2011, 03:42:09 PM
Read 453 times
jdrago
« on: July 30, 2011, 03:42:09 PM »
Hi,  I am putting a fresh water system in my 95 225 and was wondering if anyone had ideas on where to mount the tank and fill spout?  Not sure where the orginals went as mine didn't have this.   Was planning on installing the sink in the cabin, a transom wash down and associated tank and pump.  Wanted to use a collapsible tank and on demand pump?
Any ideas out there?
Jim
July 30, 2011, 06:06:10 PM
Re: 225 Freshwater system
« Reply #1 on: July 30, 2011, 06:06:10 PM »
The factory setup had the tank on the port stringer,behind that wall next to your port side seat,you can access that are thru the cabin and that cubby hole by the seat can come out if you need it to,and the fill was put above that on the outside of you walk area,the pump was mounted on the port stringer in back by the oil tank. :salut:
