On one that size I would try to use 2 straps. I wish I would have noticed your location last week, I stayed on 204 at 95 and was in Hinesville training students at Savannah Tech. I would have liked to see your hull. I hope to be back there in a couple of weeks, maybe we can work something out at that time.
Back to the tank, where are the fill and pickup lines on the tank? I would worry more about the poly "swell" on the top of the tank. Make sure you seat the shelf low enough that it can never be hit by the hatch cover or deck.
OK have a question. I got a new tank in the mail this past week. I opted for a 63 gal poly. Does it have to be mounted inside a "coffin"?
I was planning to mount it centerline on an encapsulated plywood "shelf" with 6" lips at each end to keep it in place, leaving an inch or so of "expansion play" all the way around it. The ply shelf would be glassed to the stringers the entire length on each side. Ideas?Thanks!
Deconstruction is mostly over, here are some pics...construction(foam first) has begun.In this pic you can see an old deck repair with storage added, but no drains...there were 40-50 gallons in each of the two front compartments they added. The main culprit to wet wood.35lb anchor lost under fuel coffin for yearsready for some cutting, grinding, and glassing(and more itching)
That was the PO's spare???
