Author Topic: Transom cap separation  (Read 3124 times)
February 05, 2006, 10:55:17 PM
Read 3124 times
Anonymous
« on: February 05, 2006, 10:55:17 PM »
I've had two AS', a 222 FF and a 196 FF.  Both had problems w/the transom cap separating from the transom.  Didn't see anything specifically addressing this issue in the forums.   I've also heard that it was a common problem on older AS's.    What's the story on this problem and anybody got some good info on repair?   I'd like to avoid redo of the whole transom if possible.   I now own the 196 and it is coming apart rather badly at this point.
Thanks.
February 06, 2006, 05:18:08 AM
Re: Transom cap separation
« Reply #1 on: February 06, 2006, 05:18:08 AM »
Quote from: "guest"
Thanks.
Can you post some pix to show us what you're experiencing?  We might have more input if we can see it.
February 06, 2006, 10:21:49 PM
eeker199
transom separation
« Reply #2 on: February 06, 2006, 10:21:49 PM »
Will do, as soon as I can get out in the barn to get a pic.  It's COLD in Michigan!
February 07, 2006, 08:13:51 AM
« Reply #3 on: February 07, 2006, 08:13:51 AM »
My 170 has the same cracking at the transom.  In looking at the construction pictures of the liner & hull before assembly, it appears the connection line where the liner meets the hull is where the cracking occurs.  Cause for this might be expansion of the wood core in the transom when it gets wet.  Wood will swell no matter what and probably expresses itself as the crack in the transom at the joint.  Since my transom is still rock hard all I've done to address the condition is to seal the area to prevent more warer from getting in.
February 07, 2006, 09:22:25 AM
Straight A's
« Reply #4 on: February 07, 2006, 09:22:25 AM »
I am new to the board and just getting started on a project.  Just picked up an older 17 cc Osprey.  I think my pictures might help in the discussion.......
edit.....oops can't post pics here...newbie mistake....I just posted them in the rebuilds section.
Northern Neck
Virginia
February 07, 2006, 12:03:55 PM
« Reply #5 on: February 07, 2006, 12:03:55 PM »
Yes you can post pictures in a thread.  Makes it easier to follow what you're saying if text & pix are together.
Post pictures to a thread by uploading to photobucket or whoever you use then do a copy/paste of the img file name to the thread... Rickk taught me that trick...
Anyway, if your transom has no flex to it when you bounce the tilted-up motor up & down, the transom is probably OK for now but it won't hurt to seal up the cracks to keep water out.  Like death & taxes though, the transom core will need replacement somwhere along the line.  It'll let you know when.
February 07, 2006, 03:05:11 PM
Anonymous
« Reply #6 on: February 07, 2006, 03:05:11 PM »
THanks JIm.  Actually I keep my pics on snapfish and tried the IMG thing but it didn't post them.  Maybe I will try from another computer...
February 07, 2006, 07:22:13 PM
« Reply #7 on: February 07, 2006, 07:22:13 PM »
Try
http://photobucket.com/
Works for me.
February 07, 2006, 09:35:03 PM
eeker199
« Reply #8 on: February 07, 2006, 09:35:03 PM »
Photobucket.com....just the ticket for pics...
Here are the shots of my transom from the 196 Family Fisherman.  What do you think?   How can I deal w/this?  Transom seems very solid otherwise.  Boat is a 1984, I think.
Thanks.
February 07, 2006, 09:50:26 PM
« Reply #9 on: February 07, 2006, 09:50:26 PM »
That's the line where the hull & liner join.
Hull:
Liner:
Joint at the transom was faired out with polyester putty only I believe.  No glass tape, hence the crack.
February 08, 2006, 08:56:52 PM
eeker199
« Reply #10 on: February 08, 2006, 08:56:52 PM »
Interesting information.  This provides some insight into how the whole thing came about.
Has anybody done the repair and willing to offer some advice?
Thanks.
