Author Topic: Hate asking this question, but got to......Why are my scuppers underwater?  (Read 5086 times)
August 05, 2011, 06:51:43 PM
Reply #45
imonna 19 6
  • NorthEast
Re: Hate asking this question, but got to......Why are my scup..
« Reply #45 on: August 05, 2011, 06:51:43 PM »
Circle, I'd consider anything that would reduce the weight so I am getting more than .75 miles a gallon (estimate).
I dont have an inside pic of the scuppers on hand, but their are located at the bottom of the splashwell and here is a pic of the back
Bill
1979 19\'6" with a 99 Johnson 100
"Pull the Plug"
Northern CT
August 05, 2011, 08:12:46 PM
Reply #46
« Reply #46 on: August 05, 2011, 08:12:46 PM »
Thanks for the stern pic.
If she's getting that mileage, and top-end as you describe...CH may have a good fix short-term.
Guess you saw the "wet foam" post...we made need to think along those lines.
August 05, 2011, 09:16:30 PM
Reply #47
imonna 19 6
  • NorthEast
« Reply #47 on: August 05, 2011, 09:16:30 PM »
Yeah gran, I am thinking of heading on that direction.
I do not care about cosmetics at this point because at some point the deck and transom will need to be redone anyway.  Since everything is solid, it could withstand some exploratory holes that I patch up.  I have all the west epoxy and cloth i need on hand, so I guess the only choice is where would the best location be for a single hand sized hole that would allow me to get a good view of the space between the stringer and the side of the hul and reach as much foam as possible.
As a refresher and justification for why i think my weight is on the outside of the stringers, here is what i found on the starboard side when doing the tank
Busted fishbox drain throughhull
and it was surrounded by this
which was bone dry at the top, but soaked at the bottom.
I have had my boat pitched in my driveway at around 20 degrees to stern all week, so if i have a chance of getting water, now would seem to be it.
Bill
"Pull the Plug"
Northern CT
August 05, 2011, 10:00:41 PM
Reply #48
« Reply #48 on: August 05, 2011, 10:00:41 PM »
Good deal. This thing ain't gonna whip us.
August 07, 2011, 08:02:17 AM
Reply #49
Mike453
  • NorthEast
« Reply #49 on: August 07, 2011, 08:02:17 AM »
Sorry for cumming in late, I remember a post when I first joined, A member drilled and installed an air fitting in the forward portion of his stringer and another at the rear in the bilge. put light air pressure to the front, and water comes out the back. I don't know if it worked, but it sounds like it would. Just another option before you start cutting holes in your boat! Good luck .
2000 aquasport 200 osprey with 115 johnson
