Author Topic: Ordered Float Switches  (Read 865 times)
July 13, 2011, 03:14:34 PM
Read 865 times
225Explor
« on: July 13, 2011, 03:14:34 PM »
waiting on these 2 switches to mate up with the forward and aft bilge pumps for my 225................Anyone ever try these yet ?
Edit: hahaha forgot to put up the link  :scratch:  :scratch:
http://www.westmarine.com/webapp/wcs/st ... sNum=10625
1995 Aquasport 225 Explorer
26\' Pacemaker Wahoo
July 13, 2011, 06:23:56 PM
Re: Ordered Float Switches
« Reply #1 on: July 13, 2011, 06:23:56 PM »
Quote from: "225Explor"
Can't say I ever saw those type before but they appear to "blend in" well. :?
July 13, 2011, 07:03:53 PM
« Reply #2 on: July 13, 2011, 07:03:53 PM »
I've been using the Johnson switches - matches my, uh...
http://www.youtube.com/watch?v=d2gIdMRwfuM
July 14, 2011, 04:19:46 PM
225Explor
« Reply #3 on: July 14, 2011, 04:19:46 PM »
anyone try this switches yet ?
July 14, 2011, 09:27:09 PM
« Reply #4 on: July 14, 2011, 09:27:09 PM »
This is the first time i've seen those,i'm sure they will work fine,let us know what you think when you get them installed and include pics :)
July 15, 2011, 12:07:51 PM
225Explor
« Reply #5 on: July 15, 2011, 12:07:51 PM »
Quote from: "Circle Hooked"
I had thought of using the other johnson switch that is available.  Decided to give this one a try due to the float itself being "inside". and protected.  Will post result when its complete.  I'll be attacking the dreaded aft bilge without Pete's pieplate method as I just do not have the time to extend the project.
MikeR
July 15, 2011, 12:10:52 PM
225Explor
« Reply #6 on: July 15, 2011, 12:10:52 PM »
forgot to mention....offered my 100# buddy a case of beer to reach in there  :lol:  :lol:
July 18, 2011, 03:43:50 PM
« Reply #7 on: July 18, 2011, 03:43:50 PM »
It can be done,i did it and i'm not a little guy,remove the whole frame of the rear hatch and you will gain some room,i also removed the batteries,gave me room for my left shoulder when i was reaching down.
July 18, 2011, 09:59:34 PM
225Explor
« Reply #8 on: July 18, 2011, 09:59:34 PM »
thanks for tip scott, I did take that frame off and it did help BUT, ran into a new problem, the heads of all the screws that fasten the bilges and floats are all shot. I literally can not unscrew any of the 8 total screws to the forward or aft pumps.  I also need to be careful with those old floats with mercury.  I'm beginning to wonder if stainless screws were even used, can't tell cause I can't get any of them out,  I have tried all size screw bits and none even catch a slotted groove.   :scratch:  :scratch:  :scratch:
July 18, 2011, 10:55:39 PM
« Reply #9 on: July 18, 2011, 10:55:39 PM »
This design is tried and true....had an old leaking wooden boat in the late 70's early 80's...Sent the Lovett Pump back to the factory every year for reconditioning...$19.95..year after year :oops:
http://www.lovettmarine.com/pumps/1200-bilge-pump.asp
The switch you have is exactly the same...minus the pump.
You'll be pleased....good stuff, and won't get hung on "ON" by debris/flotsam.
July 18, 2011, 11:09:57 PM
« Reply #10 on: July 18, 2011, 11:09:57 PM »
Quote from: "GoneFission"
Forget the pump. Watch this link again. You're gonna Lovett :thumright:
(Don't need no Evinrude)
July 18, 2011, 11:14:40 PM
« Reply #11 on: July 18, 2011, 11:14:40 PM »
Is there enough of the screw head exposed to get vise grips on them ?
Post a pic if you can so we can see what your dealing with,we will come up with something,always do  :thumright:
