Thanks Seabob. Should I ground both wires to the ground bus? Should I ground both wires to the same post or a different post?Knowledge question: why does the system need a shield wire if the thicker negative wire is grounded?ThanksDxs
Done and done.System looks great. Had to remove windshield to mount it on helm but fits nicely. GPS timed right in. Won't get to do a water test until next weekend. Hopefully the transducer will work.Is there a way to test the transducer out of the water? Probably not...
Quote from: "dxs217"Done and done.System looks great. Had to remove windshield to mount it on helm but fits nicely. GPS timed right in. Won't get to do a water test until next weekend. Hopefully the transducer will work.Is there a way to test the transducer out of the water? Probably not...Some will read, some will just show the dotted lines...Marc, what about a Fosters can? Might as well get some variety here...
