Author Topic: 1985 Evinrude 30HP Foot  (Read 688 times)
June 26, 2011, 08:45:18 AM
Read 688 times
« on: June 26, 2011, 08:45:18 AM »
Hey guys,
working on a 1985 30 HP Evinrude for a friend, trying to remove the foot.  Unlike the larger OMC motors I have worked on, this one does not have a clevis and pin connection under the powerhead that you would remove to release the shift rod.  THE POS Seloc or Clymers? manual showed dropping the foot down a little and there would be a screw you could access between the midsection and foot seperation area which releases the shift rod, but that is not the case.  Up top the shift lever shaft goes through a journal and connects to the top of the shift rod somewhere under the powerhead but inside the lower cowling which appears un accessible without removing the powerhead?  A diagram on Iboats shows a circlip on the shift lever shaft, and a flat end which apparently engages the rod to move it up or down.  Any help is appreciated. Thanks
June 26, 2011, 09:13:46 AM
Re: 1985 Evinrude 30HP Foot
« Reply #1 on: June 26, 2011, 09:13:46 AM »
Here's the exploded diagram off BRP.com Don't know if it will help but good luck! Well that didn't work but you can put the year and model # and zoom in to see just what is there!
http://shop2.evinrude.com/Index.aspx?s1 ... 0&siteid=1
June 26, 2011, 12:23:07 PM
« Reply #2 on: June 26, 2011, 12:23:07 PM »
If I'm not mistaken, remove the water intake screen and you shall find what you seek!
June 26, 2011, 06:40:08 PM
« Reply #3 on: June 26, 2011, 06:40:08 PM »
AND Fitz is the winner  :cheers: as the saying goes, you should learn something new each day... and I did.. Thanks Fitz...
