Author Topic: painting the AS  (Read 4881 times)
June 20, 2011, 11:50:55 AM
Read 4881 times
painting the AS
« on: June 20, 2011, 11:50:55 AM »
prepping the boat to get painted, removing everything small from the hull sides, transom and console,
the hull sides/transom and center console will be painted Awlcraft® 2000 "dark gray"
heres the color
June 20, 2011, 12:00:38 PM
MarshMarlowe196
Re: painting the AS
« Reply #1 on: June 20, 2011, 12:00:38 PM »
I love the color  :pl:  Can't wait to see it when it's done  :salut:
Key West 1720 / Yam C90
Sold: 1973 Aquasport 19-6
June 21, 2011, 10:44:03 AM
ANTIBLING
Re: painting the AS
« Reply #2 on: June 21, 2011, 10:44:03 AM »
Where are you located in St. Pete? I plan on using awlcraft in the near future and would like to check out how your finish comes out
87\' 170 striper
June 21, 2011, 12:03:20 PM
Re: painting the AS
« Reply #3 on: June 21, 2011, 12:03:20 PM »
NE St Pete, shore acres, near the fire station.
 just got of the phone with my painter to set an approx date to drop the boat off at his shop, which will be the tuesday after after july 4th or the following monday...
the next 2 weeks will go by so slow because im waiting for something!:bounce:
June 21, 2011, 01:50:06 PM
ANTIBLING
Re: painting the AS
« Reply #4 on: June 21, 2011, 01:50:06 PM »
I never noticed either of your boats coming out of the canal, my dad lives on Venetian and Shore Acres Blvd. Who are you having spray the boat?
87\' 170 striper
June 21, 2011, 02:11:42 PM
Re: painting the AS
« Reply #5 on: June 21, 2011, 02:11:42 PM »
my dad keeps his boat at Madeira beach marina, and i keep the AS at my work (Harborage marina), only time i bring the boat home is to work on it, unless its rough, out i hardly ever go through the canals.
one of my parents friends works for marine max, does paint, gel, and glass work. he's doin the work
June 21, 2011, 03:23:43 PM
Re: painting the AS
« Reply #6 on: June 21, 2011, 03:23:43 PM »
todays work:
started to remove the rubrail but my drill charger took a crap...
started filling and sanding the console:
June 22, 2011, 11:51:57 AM
wrightex
Re: painting the AS
« Reply #7 on: June 22, 2011, 11:51:57 AM »
Aaron,
I'm just over the "bridge" from you in Manatee County and will looking for somebody to paint my '70 22-2 soon. Would your guy be interested? It's a bare hull/floor - no console or motor.
Also, I was going to look into Salt Creek marina for the bottom job (redo existing). Any comments/suggestions.
June 27, 2011, 01:39:10 PM
Re: painting the AS
« Reply #8 on: June 27, 2011, 01:39:10 PM »
Quote from: "wrightex"
Aaron,
ill check with him when i drop the boat off at his shop next week...
couldnt wait to do something, painted the console over the last few days with Interlux Brightsides "steel gray" using the roll and tip method...
total of 5 coats, waiting at least 5-6 hours between each coat, came out pretty smooth. mixed a little too much thinner on the last coat started getting a few runs... its lighter than i was expecting out in the sun... still need to touch-up in the nooks and crannies..
June 27, 2011, 02:04:38 PM
Re: painting the AS
« Reply #9 on: June 27, 2011, 02:04:38 PM »
Love the color... "Haze Gray and Underway"  Nice job applying it  :thumright:
June 27, 2011, 02:10:36 PM
Re: painting the AS
« Reply #10 on: June 27, 2011, 02:10:36 PM »
i actually applied 6 coats, with the last coat straight from the can, no thinner. looks as if it was sprayed on, almost perfectly smooth :cheers:
June 28, 2011, 11:55:45 AM
Re: painting the AS
« Reply #11 on: June 28, 2011, 11:55:45 AM »
continuing work on the boat today, piecing the console back together... came up with an idea for the jackplate rocker switch that didnt involve drilling any more holes in the console... used the blank space on the omc shift cover, cut out a small rectangle with the dremel and a cutting bit:
also used the hole where the compass was for an extra cup holder, will be ordering a new windshield from upd plastics once the boat is done painted...
July 01, 2011, 08:31:54 PM
adpostel
Re: painting the AS
« Reply #12 on: July 01, 2011, 08:31:54 PM »
Great progress! My 19-6 is in the middle of a complete re-do as well.  Kuddos to you for your progress, as mine is going alot slower..... But I'm getting there.....  Good Luck and keep up the good work.
1978 Aquasport 19-6 w/ 1978 Evinrude 140
July 01, 2011, 09:05:06 PM
Re: painting the AS
« Reply #13 on: July 01, 2011, 09:05:06 PM »
thanks! yeah she's coming along. she'll be getting paint next week or the week after... and a new(er) aluminum tandem axle trailer after that
July 05, 2011, 05:42:37 PM
Re: painting the AS
« Reply #14 on: July 05, 2011, 05:42:37 PM »
just got off the phone with my painter, dropping the boat off tomorrow afternoon! :bounce:
