Author Topic: water temperature instrument  (Read 673 times)
June 11, 2011, 04:12:43 AM
Read 673 times
nightrain76
« on: June 11, 2011, 04:12:43 AM »
hi,i've got a 1996 ocean runner 90hp and i would like to connect the water temperature instruments but i don't know wich is the signal cable,thank's
June 11, 2011, 11:43:03 AM
Re: water temperature instrument
« Reply #1 on: June 11, 2011, 11:43:03 AM »
The tan wire.  You'll probably find a pigtail on the engine harness by the tach, unused...
June 11, 2011, 01:21:39 PM
nightrain76
« Reply #2 on: June 11, 2011, 01:21:39 PM »
but if i don't get wrong i don't think i have a tan wire from my wiring harness
June 11, 2011, 01:55:06 PM
« Reply #3 on: June 11, 2011, 01:55:06 PM »
Do you have a SystemCheck tach or gauge?  It will have an large deutsch connector plug on the back (forget how many pins).  You'll see a tan wire in that plug, it should branch out further down the harness to allow for a temp gauge hookup...
June 13, 2011, 09:40:36 AM
« Reply #4 on: June 13, 2011, 09:40:36 AM »
Consider a water pressure gauge vs. a temp gauge.  By the time it overheats, it's too late.  You will see low water pressure before she starts getting hot...    :thumleft:
June 13, 2011, 10:07:33 AM
« Reply #5 on: June 13, 2011, 10:07:33 AM »
Use both if you can; a water pressure gage will not help when a thermostat sticks closed. You can have great water pressure and still fry the powerhead.
June 13, 2011, 10:12:29 AM
« Reply #6 on: June 13, 2011, 10:12:29 AM »
Right on Fitz.   :thumleft:   Of course, Murphy's law says the themostat that is stuck will never be on the cylinder bank  with the temp sender.   :oops:
