Author Topic: 2003 Explorer 250  (Read 740 times)
June 09, 2011, 12:25:19 PM
Read 740 times
billmaine2011
2003 Explorer 250
« on: June 09, 2011, 12:25:19 PM »
Greetings.  I have removed the two hatch locks on the top lid that closes over the door to the cabin.  I have not found any replacement locks like the ones I removed.  Any suggestions?  I can take pictures if needed.  They have a round key.
Thanks,
Bill
June 09, 2011, 02:13:46 PM
Re: 2003 Explorer 250
« Reply #1 on: June 09, 2011, 02:13:46 PM »
Quote from: "billmaine2011"
Thanks,
Bill
Southco should have just about anything you could want, they are a large supplier of latches and hasps.... http://www.southco.com/
also a good resource is http://www.mcmaster.com/# type in latches in the search, look through their selection and find out what your latches are "called" or the type of latch you have, then start searching, you can drill down through their menu and select size, material (stainless of course) etc...
June 09, 2011, 08:05:54 PM
« Reply #2 on: June 09, 2011, 08:05:54 PM »
Welcome aboard billmaine2011  :!:  :!:
If the locks were like mine with the round key and you are looking for keys, it's a standard freezer key.  Get them at ACE.
May 24, 2012, 02:00:10 PM
billmaine2011
« Reply #3 on: May 24, 2012, 02:00:10 PM »
Quote from: "RickK"
Yes, those are the ones.  I had to cut the locks off due to the rust.  Complete replacement I need.
Thanks,
bill
