Author Topic: Hatches  (Read 608 times)
June 07, 2011, 07:46:34 PM
Read 608 times
Mark Sr
Hatches
« on: June 07, 2011, 07:46:34 PM »
Has anyone installed a hatch in the rear area of the swim platform on a TM or Osprey.If so do you get any water in the bilge splashing in through the hatch cover.I have wires to get to and the hose came off my fish box pump and there's no room to get it back on?If I put a hatch cover there I'll have acess to the rear of boat.I'm also worried if it will weaken transom area.
Mark Sr
June 07, 2011, 07:56:30 PM
Re: Hatches
« Reply #1 on: June 07, 2011, 07:56:30 PM »
Mark,
I put a pie plate in my fish box,it gives good acsess to the bilge and livewell
 :salut:
June 07, 2011, 08:04:57 PM
Mark Sr
Re: Hatches
« Reply #2 on: June 07, 2011, 08:04:57 PM »
Hi Pete
Do you have any leaking into bilge area with the pie plate.I don't want any fish slime leaking into bilge area to make it smell.It sounds like a good idea.Is it mounted on the side wall of the fish box?
Mark Sr
June 07, 2011, 09:09:44 PM
Re: Hatches
« Reply #3 on: June 07, 2011, 09:09:44 PM »
Yep,inside the fish box,sealed the mounting ring with 4200 doesnt leak :salut:
June 07, 2011, 09:37:24 PM
Mark Sr
Re: Hatches
« Reply #4 on: June 07, 2011, 09:37:24 PM »
Pete,what's the one under the plate?What size is the plate?
Mark Sr
June 08, 2011, 03:43:22 PM
Re: Hatches
« Reply #5 on: June 08, 2011, 03:43:22 PM »
Mark ,
Check out this thread,it details my fishbox upgrade,any questions let me know <!-- s:cheers: -->:cheers:<!-- s:cheers: -->
that plug below pie plate is just a drain pulg I put in where the original pump outlet was.I moved the drain to the bottom of the fishbox <!-- s:salut: -->:salut:<!-- s:salut: -->
http://classicaquasport.com/smf/index.php?topic=6311.0
