Author Topic: Proline 24FB  (Read 4894 times)
June 03, 2011, 09:21:49 PM
Read 4894 times
Tland15
Proline 24FB
« on: June 03, 2011, 09:21:49 PM »
Just picked this boat up running it the way it is until i save up a few bucks to start the project.  I got a few soft spots on the floor that i want to fix this winter.  Wondering what kind of idea you all have that will make this boat look better.  As for the project my ideas I have so far are to close in the transom with 2 crab buckets and a 25 oval livewell in it, redo all the stingers, bulkheads, and floor, a hammerhead livewell.  would like to change the way the from of the cap looks and make it a little flatter but cant figure out how to do that.  Let me know what ideas you guys have and things you may think may make things easier in my process.  This will be my first rebuild so any help will be nice.  Also from experience does anyone have an estimate on how much the stringers, bulkhead, floor and transom will run?
Thanks for the help
June 03, 2011, 09:29:13 PM
Tland15
Re: Proline 24FB
« Reply #1 on: June 03, 2011, 09:29:13 PM »
June 03, 2011, 10:51:39 PM
Re: Proline 24FB
« Reply #2 on: June 03, 2011, 10:51:39 PM »
Sweet!  Can't wait to see you start up the rebuild...
June 06, 2011, 06:34:29 PM
Capt Matt
Re: Proline 24FB
« Reply #3 on: June 06, 2011, 06:34:29 PM »
Was that proline a Boca Grande guide boat?  it looks very familiar almost like I have seen it around. It run ok with a 115hp?
The 24 proline seems almost identical to a 22 flatback with the same beam its almost like they just added 2 feet to the aquasport mold.
Rebuilding stringers, floor and transom with coosa + fiberglass + resin cost roughly $5K. Thats just materials no rigging, paint etc etc. I stopped saving receipts about 3 months ago as I don't even want to know how much $ I have invested in it anymore. These flatback boats are a labor of love and like anything else the sky is the limit when rebuilding them.
Good luck with the rebuild
Capt Matt
Light tackle sportfishing
June 07, 2011, 08:54:52 PM
Tland15
Re: Proline 24FB
« Reply #4 on: June 07, 2011, 08:54:52 PM »
It runs fine with the 115.  In the future looking to put a 225 on it but thats down the road.  If it is recent in Boca you may have been seeing me I've been out a couple times in the past week. Thanks for the estimate got to save a little before i get started on the project.
Is it possible just to add to the transom instead of completely rebuilding?  The transom was done not long ago I just want it to be flush with the rest of the deck.
Thanks,
Tim
June 07, 2011, 09:15:36 PM
Re: Proline 24FB
« Reply #5 on: June 07, 2011, 09:15:36 PM »
should be no problem,grind down surrounding glass to feather in new glass laminate marine ply or coosa to fit glass in fair and paint :salut:
June 22, 2011, 09:13:14 PM
HOOK
Re: Proline 24FB
« Reply #6 on: June 22, 2011, 09:13:14 PM »
I am new to the site, and I am looking into getting a project boat! I really like the FB 24' Proline and the Aquasport 222. I just have a few questions. First what is the beam width of the FB 24' Proline? And second, what are some pros and cons of the 24' proline vs. the 222 Aquasport? And last, how did you go about finding that 24' Proline?
         Thanks in advance- Sam
June 23, 2011, 04:36:20 PM
Hawg Hunter
Re: Proline 24FB
« Reply #7 on: June 23, 2011, 04:36:20 PM »
Dont know to much about width and stuff but if you get the Aquasport You can be one of us ! and you just cant beat that  :afro:
Capt, Richard "DUKE" Bowen
Conyers Ga
1988 290 Aquasport XF
June 25, 2011, 06:39:56 AM
CaptSteveBetz
    • http://www.flatsandbay.com/.
Re: Proline 24FB
« Reply #8 on: June 25, 2011, 06:39:56 AM »
Quote from: "HOOK"
There are two different FB proline 24's. Not positive but I believe it was after 72 that they built one that was a bit wider and had higher sides. The one I have is the older version. Also not positive but I believe it to be a tad narrower than a 22.2.
Pro and cons? You gain 2 feet of deck space with a 24 and probably just a little bit better ride. Not sure what the cons could be.
I just finished building mine. I spent a month of hard core looking on Craigs List, boating forums and asking around. Finally found mine.
Capt. Steve Betz
Tampa Flats and Bay Charters
www.flatsandbay.com
813-727-8843
June 25, 2011, 11:07:07 AM
Re: Proline 24FB
« Reply #9 on: June 25, 2011, 11:07:07 AM »
Steve - did you build that yourself?  More pics please?
June 26, 2011, 06:38:19 AM
CaptSteveBetz
Re: Proline 24FB
« Reply #10 on: June 26, 2011, 06:38:19 AM »
Quote from: "LilRichard"
Yes I did. When I get some time I will start a thread and post pics.
Capt. Steve Betz
www.flatsandbay.com
813-727-8843
June 26, 2011, 12:07:21 PM
Re: Proline 24FB
« Reply #11 on: June 26, 2011, 12:07:21 PM »
MUST... HAVE... PICS.
It's a pretty boat, and a unique color!  Pls start a thread on it...
June 27, 2011, 12:18:35 PM
Re: Proline 24FB
« Reply #12 on: June 27, 2011, 12:18:35 PM »
Even though I worked for both companies LONG after these 80s models were built, I have had the opportunity of seeing a couple of old PLs brought back to the factory for floor replacements, stringer replacements, and transoms...that being said, I'd go with an AS!
June 27, 2011, 12:55:16 PM
Re: Proline 24FB
« Reply #13 on: June 27, 2011, 12:55:16 PM »
Quote from: "CaptSteveBetz"
did you add a t-top or tower to her? i want to say i saw this boat a couple weeks back docking up at fishtales
June 27, 2011, 02:22:06 PM
CaptSteveBetz
Re: Proline 24FB
« Reply #14 on: June 27, 2011, 02:22:06 PM »
Quote from: "Aswaff400"
No I have not added a Tower or T-Top. I will never add a tower to it. I may possibly add a T -Top in the future.
The color is Copper Sand Metallic.  The boat has only been in the water once just to make a few trailer adjustments. I am in the process of the final stages before I actually put her to work.
Capt. Steve Betz
www.flatsandbay.com
813-727-8843
