A chipped or stuck open reed valve or lower or upper crankshaft seal. Look for oil running down the block from underneath the flywheel or pull the lower unit and look for gas/oil running down the driveshaft. It may show up as a dryer sparkplug than the rest on the top two or bottom two cylinders. Do a compression test to varify the ring issue but I doubt thats it.
Should they be able to weld galvanized aluminum?
I am thinking about cutting out the 2 diagonal bars that brace the top at the center of the console and have them rewelded onto the top cross bar that goes across just above the windshield. Same andlges for the strength... Should they be able to weld galvanized aluminum?
Also have to work on the top of the console where the compass is. I want to remove the black plexi piece and either have white fiberglass finished or white starboard...
Blue- I'm pretty sure I'm familiar with the guy you're talking about- has a big sign in his yard right?
I think I'm going to end up with another piece of teak along the top edge of the console with maybe a lip/raised edge to keep stuff up there from sliding off.
