So Chris,Do you have to pull that choke lever to start the engine cold or do you push in on the key and she starts right up? This still doesn't explain the raw oil coming out of the exhaust. When I was looking at your engine diagrams yesterday, I was looking at your oil injection system and saw that your oil is fed directly into your intake plenum and saw an array of check valves that meter the oil going into the intake. Now if one of those check valves is stuck open, maybe on one or both of the bottom cylinders, it could cause oil to puddle in the bottom of the block just from gravity and cause the mosquito control festival on start up until it clears out. This may also explain the drip of raw oil coming out the exhaust while sitting. You have a gear driven oil pump so I'm not sure how oil could pass through the pump without the engine running and feed oil into the intake via gravity so it is the hitch in my theory. I need Loye to substantiate or dispell this assumption.
Since Chris has linkage pieces laying around pan, maybe the oil pump flow control linkage from the carb? I know on a Merc if the link arm is disconnected the pump arm is spring loaded to full dump as a safety measure which helps explain the smoke on start up but not the at rest oil loss. I might be inclined to drop the gearcase and see if everything is saturated with raw oil maybe pointing to a leaking crankshaft seal, (oil running down the driveshaft and making its way out the exhaust) I've seen that one.
Agree, but she seems to have raw, puddled, un burned oil coming from somewhere internally. Open crankcase bleed valve on the bottom letting oil puddle while running and draining at rest? That oil is before combustion on the intake side of the block. Or a internal leaking oil pump? I'm totally grasping at straws now.
Noticed some oil build-up in the pan, but can not tell where it's coming from without taking the air box off (didn't have tools with me at the time. Was thinking last night and remembered: I put a cover over the console and upper station- and realized after 2-3 days of the cover being on, the wind moved the cover some and actually moved the throttle lever forward to probably 1/3 or 1/2 throttle. These are the old school morse controls- is it possible that that opened the carbs and any other linkage- allowing the oil to flow - thus giving me the "basically" solid oil flow out of the exhaust (as I didn't have the gas tank in the boat at the time)? -maybe an easy fix/realization and also explains why the problem has not returned??
