Author Topic: need a little help with teleflex gauges  (Read 1040 times)
May 22, 2011, 01:25:17 PM
Read 1040 times
Mcdiver
« on: May 22, 2011, 01:25:17 PM »
Since the revamp of the teleflex web site, all of the technical manuals are gone.  Does anyone out there have the technical manual on the install of the temperature gauge?  I have been working on the gauges in the boat and the wiring is not making sense.  I understand the light power and ground hook-ups, but I am confused on the S and I terminals.  I am assuming that the S terminal goes to the sensor and the I goes to the ignition power?  Can anyone confirm this for me so I don't blow up a nice set of gauges?
Thanks,
Mike
Mike
May 22, 2011, 02:25:14 PM
Re: need a little help with teleflex gauges
« Reply #1 on: May 22, 2011, 02:25:14 PM »
Mike,
S=Sender
I=Ignition (switched)
G=Ground
Typically the water temp is a tan wire in the engine harness, no stripe...at least on OMC and Merc, go here for Jim Hebert's wondorous desciption of engine color coding...http://continuouswave.com/whaler/refere ... rCode.html
Oh, BTW, that revamp of the website is no faux paus.  Teleflex is no longer in the gauge business, that from my TF rep when I was at Proline...
May 22, 2011, 06:23:30 PM
Mcdiver
« Reply #2 on: May 22, 2011, 06:23:30 PM »
They must be using the auto meter gauges, i saw a press release saying they would continue to supply gauges.
Thanks on the designations though, I wanted to make sure before I hooked them up.
Mike
July 11, 2011, 02:46:50 PM
PaulR
« Reply #3 on: July 11, 2011, 02:46:50 PM »
Hi Mike, I am looking for a Teleflex MK27 tachometer for my 22-2 1975 Family Fisherman, can you tell me where you got your gauges? Mine works but the glass is cracked (after only 36 years!). I saw one on eBay used but the outside frame looked in rough shape. Any help appreciated!
Thanks,
PaulR
July 11, 2011, 02:57:31 PM
« Reply #4 on: July 11, 2011, 02:57:31 PM »
Quote from: "Mcdiver"
I'm betting Faria will supply them.  Autometer is not in their price league...
