Is that 1708 going to be your finished deck? If so you will probably have to skim and fill it.I laid one layer of 1708 which I have to still sand out any lumps etc then I'm going with one layer of 1oz mat over the bi-axle. Hopefully this will give me a smoother finish.Your boat is looking goodCapt Matt
One more thought (unrelated) did you add any glass to your chines? If not, DO IT NOW before you permanently secure your floor! I saw another rebuild where the chines were stress cracking pretty badly. I have had ZERO issues because I added extra glass.
What I did (and it may not be the ideal for you): I hit the floor with a grinder (like a 36 grit - it took the high spots off), then skimmed the whole thing with filler. Here's a trick I learned from a local guy: you can add a little bit of resin to your polyester based fairing compound to make it easier to spread, and kick a little slower. Then I hit that with the orbital and the board sander, and repeat. I did not get my floor perfect, because non skid will hide a lot of minor imperfections.
