Engines & engine woes
Motor "hiccup" question
Topic: Motor "hiccup" question (Read 1052 times)
May 10, 2011, 06:04:44 PM
Read 1052 times
imonna 19 6
NorthEast
May 10, 2011, 06:04:44 PM »
Hi all,
So out in the sound for the first time today. My 1999 Johnson 100 HP outboard purred most of the day. idle good, high/mid RPM good; hot start good, cold start good. Spent about 5 hours on the water and about 1:30 running the motor
Once, and only once after coming down in rpms quickly as I approached a stopping point, it stalled, then had a hard time restarting (perhaps flooded). Started in neutral and throttled up quickly and it stayed running but sounding off for about 2 minutes; then when down throttling, repeated this whole process once more, except the second time after a few minutes of full throttle it worked out whatever kink happened and sounded fine the rest of the time.
when it sounded off at high rpm, it was still delivering full power. The sound was a purr with an occasional light/quit pop, no loss of rpm.
user error?
indicative of a common problem?
any thoughts?
Bill
1979 19\'6" with a 99 Johnson 100
"Pull the Plug"
Northern CT
May 10, 2011, 06:34:46 PM
Re: Motor "hiccup" question
May 10, 2011, 06:34:46 PM »
When did you last change your fuel filter? With ethanol fuel you need to change them twice as often. You do have a water separating fuel filter right? :) also pull your plugs and see how each cylinder is burning. I would bet it is a fuel problem but you could have a coil or something breaking down when it gets hot too.
May 10, 2011, 11:20:30 PM
May 10, 2011, 11:20:30 PM »
Could have had a piece of trash that got into the system. You do have a new tank and hoses!
I would go with WT's suggestion and change the filter and see if your motor has an inline filter just before the carbs. Not sure about that exact model.
May 11, 2011, 07:17:44 AM
imonna 19 6
NorthEast
May 11, 2011, 07:17:44 AM »
I'll check the racor. dont have any other filters.
Bill
"Pull the Plug"
Northern CT
May 11, 2011, 09:54:27 AM
Purgatory
May 11, 2011, 09:54:27 AM »
It was most likely as Lew said fuel-related. Just a hiccup.
Its a Johnson. Had a bunch of them. They all have smoker's cough.
May 11, 2011, 10:05:52 AM
May 11, 2011, 10:05:52 AM »
Quote from: "imonna 19 6"
I've got an 2004 90 HP (same motor as your's) carb'd motor on our pontoon, and it does have an internal filter screen type, not sure where, but the dealer showed me the nasty thing last year when I was having issues, it was fulll of that yellow ethanol by-product. Probably in the fuel pump inlet/VRO housing.
May 13, 2011, 07:32:29 PM
imonna 19 6
NorthEast
May 13, 2011, 07:32:29 PM »
Took it out last night and that "Hiccup" was there on the seven mile run upstream. when I got there I changed the racor, which looked clean, and then trolled for an hour straight and it sounded good. Shut it down and bottom fished for 30 minutes. When i started back up, my little problem got much worse. Spent 40 minutes running back to the ramp with constant rpm loss, knocking, and sputtering. Had it in the the water for four days, but now its back at the mechanic for a diagnostic.
Since carbs, stator, rectifier, plugs, filter, fuel, fuel lines are all new, I am guessing I have an electrical issue. Who knows.
We'll see what the mechanic says next week.
Bill
Bill
"Pull the Plug"
Northern CT
May 14, 2011, 08:21:40 AM
May 14, 2011, 08:21:40 AM »
Bill, check out part # 28 --- fuel filter. I thought there was one in there.
http://shop2.evinrude.com/Index.aspx?s1 ... 0&siteid=1
It should be pretty easy to replace yourself or at least check the condition.
May 14, 2011, 01:27:47 PM
imonna 19 6
NorthEast
May 14, 2011, 01:27:47 PM »
Its at the shop now, so i will either have them check it or check it myself when i get it back. something went wrong with the ignition electrical and may or may not be related to the fuel supply.
Thanks for the link. i bookmarked it becasue i expect i will need it in the future.
Bill
"Pull the Plug"
Northern CT
May 20, 2011, 09:22:47 PM
imonna 19 6
NorthEast
Reply #9 on:
May 20, 2011, 09:22:47 PM »
turns out the power pack was bad and #2 cylinder wasnt firing quite as much as the others....thats what i figured it was after doing some reading.
Get it back next week and back to the shore.
Bill
"Pull the Plug"
Northern CT
