There's some misinterpretation being thrown around about not sealing the wood completely regarding one of my past posts- what I was told by several wood boat builders - that leave their boats in the water most of the year - was to coat the wood completely with thinned resin, then coat the sides & bottom of the decking with regular non-thinned resin, lay the deck out & screw down then glass over the top. I used this method on my 23' boat in 1995 & it's still solid. The boat stays outside year round, but I do keep the hatches open to let it breathe. I'd never leave just raw wood on the boat anywhere. Heres a pic of the wood from around 2004 when I cut out a hatch opening, 5/8" BC plywood, not even marine ply.The previous owner had completely encapsulated the wood deck with glass, then screwed it down. The screws were not sealed well, water definitely got to the wood, his deck lasted about 5 years or less I'm guessing when I got hold of the boat, by then the deck was mush. The extra layer of 24oz roven he used on the bottom side didn't help much strength wise, sealing up all the screw holes is key.I do think that if water had never gotten to the wood it would've been fine wether it's glassed on both sides or just the top.The wood by itself is plenty strong, the glass is only there to protect it, you really don't need to glass both sides for strength. Foam core then yes both sides but thats a completely different scenario. 3/4" marine ply is overkill for the deck, 5/8" is enough unless you've got some huge unsupported areas in which case you should build some kind of reinforcement grids to the deck. The factory 19' boats came with 3/8" ply.
...natural crown...
I`m not trying to re-direct the dialog by any means just one question. When I recore the front hatches on the 22-2, how do I keep the hatches from bowing while the resin and glass cures? Wax paper, cinder blocks and prayer? Thanks!
All we did was cut 1/2 plywood as large as would fit but not interfere with the covers going back in place. We sealed the ply with resin while grinding down the under side of the hatches. We put the hatches upside down on his garage floor and used thickened resin to attach the plywood to the hatch. We piled everything we could find on top of the plywood. Blocks, anvil, anything that had weight. Take a rag with acetone and clean up the squeeze out to save grinding later. His came out fine and those covers are larger than most hatches. It's been three years and still holding.
One of the reasons I keep old batteries around is to use them for weights.
one other thing that helps is to drill a few small holes in the core before bedding, helps alleviate air bubbles.
